What's the best lift around-based on value and performance
AZrunner11
I've been scouring 2010+ TE build threads, specifically ones with KDSS, and I'm looking for opinions of what set up is the best all around lift based upon value and performance. Your insight will be very helpful in helping me decide which direction to go. Also include responses regarding UCAs.
I'm trying to avoid being that guy that gets one set up and then I find myself changing to a different manufacturer shortly after getting the first lift installed.
Let me google that for you
The best setup is a moving target, depending on what you want from your vehicle.
Icon, Radflo, Toytec, and OME are probably the most popular setups. As far as UCAs go, the main decision is uniball or ball joint.
Since you didn't specify any requirements, you will probably be happy with any of the basic aftermarket kits.
Love my bilstein 5100/5160 and ome setup, though that said I'm moving to an extended travel Radflo/Metaltech because I want the extra travel for off roading. Not to say my current setup isn't up to trail use, but I underestimated my needs when I made the initial decision.
