Wheel question?
Calloway
Member
So my buddy just picked up a 2022 Ford Bronco. He's changing the wheels and tires and asked if I wanted them.
Will 2022 Ford Bronco wheels for on a 2000 Toyota 4 Runner?
They have the same lug pattern size 6 x 139.7. But not sure about the bore size.
TIA!
Thanks Bad Luck. Sorry I did Google and pulled up this website as well. So the bore size is different 93.1mm (Bronco) vs 106.1mm (4Runner).
I just wasnt't sure if I could still fit these on with adapters or if it was a complete no go.
Anything is possible with adapters, but to do it correctly would require hub centric wheel adapters to change the bore size down and retain hub centric alignment. Hub centric adapters are pricey and you would need all 4. The adapter spacing and bronco wheel backspacing/width might cause rubbing and other fitment issues. That juice isn't worth the squeeze in my opinion.
EDIT: Hub centric adapters have a female bore for the 4Runner and a male lip for the bronco wheel bore.
erinobr2000
