dot_tom
So, you set your 5100's at the .85" mark along with the T1 springs? Do you have UCAs as well? I have thought about moving my front 5100s to that notch to achieve a more level look, but can't decide if i should get UCA's at the same time?
Yes. I ran the T1's at the .85 setting. I wasn't a fan of the ride on or off-road. Seemed too stiff and the suspension wouldn't flex or absorb bumps as well.
Yes, you will need UCA's to get a good alignment and CV angles over the 2.5" T1.
If you had aftermarket UCA's you could run a .5" top plate and keep the good ride and alignment spec. I also tried this .5" top plate with T1's set at zero and it rode nice. Just needed UCA's for alignment.
I like the 2.5" setup the most for ride and to help with the COG due to Gobi and RTT.
This is T1 at 0 and T13 with 1" rear spacer.
