Where do these washers go on a TRD Pro Suspension?
Rogue-Runner
I'm just buttoning down everything after installing a 2017 TRD Pro Suspension on my 2016 SR5, although I'm not sure where these washers go or if they're necessary (see pic). I have two sets of these, so 4 washers in total. Two have a little cross etched in them. I've checked the parts and repair diagram on the front and rear suspension but I'm not seeing them anywhere. I've looked at pictures and can't tell from that either where these go. Others show some black washers that are connected to the rubber piece but none show these additional nickel washers. Can anyone identify these? I'm pretty sure they go on the rear somewhere, but I could be wrong.
Also, the little hooked tab that you use to mount the bracket to mount
the reservoir fell inside a little hole inside the frame and I think it's lost forever... Anyone know if a hardware store would carry these or if I need to go to Toyota? Thanks!
Those remind me of UCA washers.
Wow I think you're right! The TRD setup that I bought came with UCAs but they're the same as SR5 so I didn't bother with them. You'd think there would be 8 washers instead of 4 though. I'll double check. Thanks!!
All stock 4Runners have the same UCA's, even TRD Pro's. So unless you changed out your UCA's then you should be fine.
Yup. I just hope that's what these washers are for and not for some other component that's going to have them missing. Still not sure why I only have 4 though.
These are used to mount your rear reservoirs :-)
Right, it's just the big washers I was confused about. I think the comment above belonging to the UCAs is correct (at least I hope because it's all done!).
The picture cut the words off in the middle of my post, but my problem was that when trying to install the reservoir bracket the little screw tab fell inside the hole and is currently inside the frame. I don't think I can get it back (unless I were crazy enough to slice open the frame). I'm not too worried about it though. The reservoir is mounted, but I don't think it's rattling or anything. I might call the dealer about getting an extra one if I can't find one at Lowes.
MaximussK
