Where is the ac fuse in a 88?
Starcitygta
My ac stopped working. No light , no kick on no nothing. I just relaced radio and thinking it blew. I know its suppose to be near glovebox? Does anyone have a pic? Does the glovebox have to be removed? Any help? Thanks
Theres actually 3 fuse box's in an 88 4Runner. one of them is under the driver side dash on the left side and there is one behind the glove box and the last one is under the hood on the passenger side behind the battery
if the fuse is fine, start w/ the blower motor
Blower Repairs (Half way down)
To answer the question, it's behind the glove box.
Remove the glove box rear cover, then push in the sides so it will swing all the way down. It's inside and to the left.
Ding man thank you very much. There was a 25a fuse in the 10a ac fuse panel. It wasn't blown neither was blower fuse. I replaced with correct fuse and still no luck. Any more suggestions as to why my ac would just stop turning on. No light on ac button when it did work along with ac. Any more fuse that or relay that would cause this?
Does it blow at all when it is in the heat position? Take a look at your switch to see if it is within specs.
Pic below of the factory service manual is from the "Sticky" at the top of the "Classics" threads. It will have some other steps that you can run through.
The fan blower is working on all speeds. The ac fuse had a 25a stuck in there and it should have been a 10a in it, it wasn't blown but did appear to get hot. I put correct fuse in but still no luck. Any suggestions?
Clocktower07
