Which new rear springs?
Icon 2"spring is more comfortable and performance then Toytec spring
I'll second the Metal Tech Springs. I'm running them with the extended 2.0 Icon Remote Reservoir shocks and have LOVED them compared to the Toytec springs I had on before. On and Off Road.
Do u mean that Icon 2"spring is more comfortable and performance then Toytec spring , on and off road ???
Following closely. I was gonna get a set of iron man coils. But this is going on my wife's ride and I love the idea of a good on road experience.
None that I know of off the top of my head. You could always add a small trim spacer I think toytec sells that would fix it. The 2" MT coils, which are apparently hard to come by now, would be what you want to be level. The 3" HD coils would be a bit much IMO for the 2.5" front lift.
FYI - to fully compensate for the lean on a V8 (which is heavier), you need a 1.5" spacer. I have already tried the 10mm and 20mm spacers with no success using ARB heavy rear coils.
Thanks for the Feedback. Its Icon 2" or T-12 1 1/2".
I know is this waaaay late, but can I ask what rear springs you ended up going with? I just put 5100s all around and new front springs, but I want to lift my rear and can't decide between the 2" or 3" Icons. I've got an 05 4R with the original rear springs so it's probably significantly lower than when it was new. I want my front rake back, but I don't want to be soooo arse high it looks stupid. Thanks
Ambrose67
