Which way does the transmission plug gasket go?
You are correct. You should be able to see the way the old one sits when you pull it. I believe the Haynes says something in the 15-20lb range. I have done a couple drain/refills re-using the same gasket despite having a new one and just snugging it up by hand. No issues with leaks.
Yeah, I did a drain and fill and noticed the other day there's a slight leak now, I am thinking I might've placed the gasket the wrong way or just need a new one, also did not over-torque it, just made it snug. Thank you for confirming.
leolediola
