Which weight ratio for my tires?
Battle Pug
I am about to put GY Wrangler Duratrac's on my 2011 TE. Sized 265/70/17
Which tire should i get the "C" weight rated, or the "E""?
I use the vehicle for daily drive and light trail and mud on varied weekends.
I am not towing anything at this point. Just family and gear.
Recommendations?
Why C to E skipping D?
I am running D load Duratracs and carry a lot of crap in here, they are overkill. E loads are even more overkill.
I got myself C because load rating is good enough and C ties are lighter which is good for fuel consumption. However E tires have stronger sidewall and if were going to drive over lots of sharp rocks I would probably bought E. Just my opinion : )
I got the 265/70/17 C rated duratracs and am very pleased with them.
Essentially for the same reasons as scanny said, the C's are lighter so that helps with fuel economy. Plus I do not do a ton of towing. Wish I had a boat!!
If you stick with the stock size it sounds like the C might fit your needs.
Stu
Kaliram
