ridefast
Just came in from doing that for the first time! Then I guess to release, you just push it in some more and let go. (I hope)
Yup, start truck keep foot on brake, shift to D or R, release parking brake and go.
Not overly complicated, but will take some getting used to. I still occasionally fish around for the clutch with my left foot...LOLYup, start truck keep foot on brake, shift to D or R, release parking brake and go.
The most common reason for the parking brakes to seize up on the older vehicles is rust forming inside the cable sleeve where the cable mounts to the rear backing plate. It happened to both sides of my '03. I had to replace both cables, about a year apart. Which is a BIG PITA. I guess, looking back, that spraying a lubricant into this area once a year or so wouldn't hurt, and frequent exercise of the cable would also be a good idea.
Are you saying that's a frequent cause in general or related to 4R's specifically? I used to have this problem with my old stick shift Audi, but I was told it's because the cable jacket is compromised so there's water or condensation inside that freezes and prevents the cable from moving inside the jacket when you release it. Rust makes sense too are far as restricting cable movement or causing it to bind, but I can't see how that would be affected by freezing temps.
The stick shift sedans I drove always had the PB lever on the console.b/c you could drag it down steep slippery shit when you felt the wheels break loose. Now, DAR takes all the fun out of it...
It's been a force of habit since I started driving in 1977.
K, this is a combination old school, redneck and neanderthal, but came in very handy when my front pads and rotors were overly worn, noisy and grinding. I would apply a bit of pedal and then pull the PB, while keeping my thumb depressing the release-button on the end of lever, to assist coming to a stop.
However, I deny ever lowering a foot through the gaping hole in the floor of my Beetle, à la Flintstone.
Ooh, you guys are baaaad...The center console PB handle was also great for initiating a rear wheel 'drift' when driving a front wheel drive car.............:naughty: Used to be a lot of fun in empty parking lots during winter.
Its always a good idea to use your parking brake when parking.Thats why they call it a parking brake. when you put your transmission in park the only part that is holding your 4500+lbs vehicle from rolling is the parking pawl. locks the transmission from moving. Its also good to use your parking brake because it ensures everything is moving freely and doesn't seize from not being used.
(parking pawl in transmission picture. not a 4runner but a general picture on what it looks like)
Toyota does not recommend using the parking brake in the winter. (Page 269 in the 2016 T4R manual)
Always use it in a Manual.
Almost never use it in the Auto TR4.
...But I would use it a whole lot more if it was a hand break.
