wiggly mirror
3bears
Senior Member
my pass side mirror has gotten wiggly....loose. NOT where it mounts to the body but where the head mounts to the part comming off the body/door
I imagine there must be a bolt or something inside...looks like the only way to get to it would be to remove mirror. The 3 screws mounted low on head, visible from outside do not do any good
If that is the fix ( a nut inside) is the mirror replaceable and how ?
I have the same issue on my 02 on the driver side. Two of the 3 screws are seized in place, but I was able to improve it by tightening the one that I could get to move. At some point I'll extract the screws and see if that resolves it
My driver side mirror got hit by a 2x4 kicked up from a car in front going about 50, busted mirror, replaced that but now upper part of housing is loose from body by about 1/4", I can see a screw - here goes another attempt to tighten up....
maybe mine are siezed too as I could not get them to budge
I had the same too and was able to do a bush fix by wedging some thick insulating tape in there. I figure it’s not a “real” fix but then again is held for about 3 months now.
