will 20x9.5 rims and 295 45-20 Tires fit with no lift.
I saw a 4th gen w/ 20" bbs FJ wheels, and it didn't look lifted, same wheel dimensions, I believe he stated he didn't rub, I had them on mine w/ a 3/2 spacer lift and had no problems, didn't like the ride, but they didn't rub. hope this helps.
285/50/r20 is perfect size, the 295 is just a lil wider. compare the tire size prices, one of them is alot more cheaper.
thanks for the responses. they come with the 295 and prob wont change the tires until next spring or sooner (i dont plan on running them in the winter. riceandpho, do you think I would have any rubbing issues without a lift or spidertrax spacerS with those tires, until I purchase new rubbers?
im running 20x9 KMC XD Monsters on 285/55R20 Sumitomo HTR Sport Plus tires. The tires are a great all season and they were around $600, not bad when i was used to paying much more for 33" MT's and 37" MTs. I have the Daystar leveling kit but they would have fit without it.
wakeboardwhan, thanks for the info. I will definitely look into those going to pick these badboys up saturday hopefully I dont have any surprises when putting them on. Im already prepared to buy at least a daystar leveling kit if not 2.5/1.5 and spidertrax. I just hope theres no surprises so I can put them on and show off my new 20's
u might rub at full turn, i knoe i rub a lil on hard full turns on 285/40r22, u dont need spacers, but even if u use spacers its gona make it rub more i bet.
you rub with those tires? those are a full inch smaller than the 285/55R20's and i dont rub at all with a leveling kit and i was told i wouldnt have without it either. what width wheel are you running?
stock sport, running moda 226 they are 22 x 9.5 , it only rub once in a while, when i do hard dipping turns, but it dosent rub the crap out the liner, it just makes a small scratch thats all.
295\30R22 or 295/40R22
So presently i have on 285/50R20 being stock height slightly rub when i do a full turn to the left because of bad alignment. Am trying to sell my 285/50R20 on TRD rims and install 295/40R22. Am wondering if it may rub?
i upped my tire size to 285/45 r22 when i had them rims, works way better, more cushioned.
but now with my enkei wt4, im running 275/55 r20, had to do some trimming since i lifted a little.
285/45 r22 and 275/55 r20 is both close to the 32 inch, same as running 265/70 r17. i should of started with that instead of the 285/40 r22, and its a little cheaper at the time. 285/45 r22 will be rubber, i think i ran it at 38-40psi
