Will these 2022 Tundra wheels work?
MrHoneycrisp
Looking to replace the stock rims that are on my 06 Limited.
Currently have the stock 18in rims, but the previous owner did a bad job of painting them black
Toyota 4Runner 2006 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-Size.com
Looking here they appear to have a positive offset of 6mm is that correct? and a width of 7.5
I am currently running 265 60r18 Toyo open country AtIII tires
I would like to purchase a set of "2022 18" Toyota Tundra SR5 OEM Factory stock wheels" per the listing
But according to this website
Toyota Tundra 2022 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-Size.com
The positive offset is 60mm.
Which means the wheels will be a helluva lot closer inside and likely to rub.
Want a second opinion before I f*ck and purchase these. Would I need some spacers to make these work?
Also, looks like I would need to increase the bore size.
Only reason I am looking at doing this as I don't like the look of the black rims with the silver body paint and I want silver/grey rims.
The tundra rims are listed for $650
The other option would be to buy some aftermarket rims for around $1000...
Thanks in advance
New Tundras are 5 lug like the Toyota 100 series Landcruiser and will not fit your 6 lug truck.
older Tundras ie 2003 ish were 15" and too small for base model SR5 16" wheels.
The sr5 apparently has a 6x139.7. Picture confirms it is 6 bolt.
Apparently different trim options have different bolt patterns.... not sure why toyota would do that.
The 18" that came on the 06 Limited are 7.5" wide and 25mm offset.
I have an 07 Limited and am thinking of 17" rims when time comes to change them. They are very corroded.
60mm offset seems like a big change pushing inwards.
Sent from my Pixel 4a using Tapatalk
All the 2022 Tundra wheels are 6 lug. I have a pair of 2022 wheels I was going to try and run on my 2005 Tundra which has the same bolt pattern as our 4Runners.
The problem is the offset, you will need wheel spacers to clear the spindle.
You will also need wheel spacers that adapt from m12 to m14 threads as the 4runner conical lug nuts wallow around in the bore. Newer Tundra's must use m14 studs.
You will also need wheel spacers that adapt from m12 to m14 threads as the 4runner conical lug nuts wallow around in the bore. Tundra's must use m14 studs.
Got it. Thanks for the info. Didn’t realize the difference in the stud size. I figured bore difference would be easy to change, but alternate studs would be a pain
I also had a lot of love for playing games and I was addicted to it. I used to waste all my time on games. Then my friend told me a link so that I could end my bad addiction. These are the link Free Essays on Addiction, Examples, Topics, Outlines - WritingUniverse If you are also addicted to such an addiction, then you can end your bad addiction. On this website, you will get free tips that how you can break your bad habits. And you can also tell about this website to those people who are victims of some bad addicton.
044runner4
