Will these 5th gen Trail edition wheels fit my 2008 SR5 V6?
ddicosmo
Member
I'm looking to pick up a 2nd set of wheels for my 2008 4Runner SR5 V6 that I can use to mount all-terrain/snow tires on. I currently have the following wheels:
17" Factory OEM wheels:
Part Number: 4261135271
Product Number:W69429MS
Size: 17" x 7.5"
Diameter: 17"
Width: 7.5"
Lugs: 6
Bolt Pattern: 140mm
Offset: 30mm
Style: 5 Spoke
I have the opportunity to buy a set of 4 stock wheels off a 2015 4Runner Trail Edition. These are the 7 spoke rims that are silver with black outline. This is the only info. I could find on them:
4261135540 | 75154MB WHEEL | OEM ORIGINAL ALLOY WHEEL
WHEEL SIZE17 X 7.5
BOLT PATTERN6 X 5.5
FINISHMachined Face/Black Pockets
Will these fit my 2008 4Runner? A lookup on google shows that these wheels only fit the 5th gen 4Runners but was wondering if these will also fit 4th gen. Thanks,
Dave.
Size:17" x 7.5"
Diameter:17"
Width:7.5"
Lugs:6
Bolt Pattern:140mm
Offset:30mm
Style:5 Spoke
WHEEL SIZE17 X 7.5
BOLT PATTERN6 X 5.5
Dave.
Yes they will
Size: 17" x 7.5"
Diameter: 17"
Width: 7.5"
Lugs: 6
Bolt Pattern: 140mm
Offset: 30mm
Style: 5 Spoke
WHEEL SIZE17 X 7.5
BOLT PATTERN6 X 5.5
Dave.
should not be a problem
I have 2017 Trail Edition wheels on my 05 SE and they fit with no issues. I know offsets can be different but the bolt pattern on the 4Runner has been the same since its conception.
I just found out that my stock 17" wheels have a 30mm offset and the 5th gen 17" Trail Edition wheels I just purchased have a 15mm offset. Will this 15mm difference cause any issues? Am i going to have issues with rubbing?
Thanks for the response. Do you know if the offset of 15mm will be a problem for my 2008 SR5 V6? The stock 17" wheels have an offset of 30mm but the 2015 Trail Edition wheels have an offset of 15mm which I believe will make them stick out a bit more. I plan on putting 265/65-17 AT tires on the new wheels so I'm sticking with the stock tire size. I'm just not sure if the offset will cause an issue.
how did the wheels and tires workout??????
Hey, I’m looking to buy a set of 2021 TRD trail wheels on my 2008 Sport. What happened with yours? Did they work out? Was got bot use the stock tire size but don’t want rubbing and have stock suspension. Guy wants $500 for a set of 4”.
