Winch Switches (Picture Request)
sigepbiker
Member
I've seen winch pictures in other picture threads. I'm leaning toward a hidden winch.
I'd like to add a switch inside for operating the winch and would like to see what you did!
Also, are there specific winches I need to look into or do all winches have the ability to have a switch wired to the cab?
A winch for me is a JIC thing so I did it like this.
P1010953_zpsn11vz5cr.jpg~original
here's the old truck...not a great pic...right above the trailer controller
[MENTION=47340]Titanpat57[/MENTION] Thanks! Not my style, but those are the pictures I'm looking for.
[MENTION=80048]SecretSquirrel[/MENTION] I know about OTRATTW's rockers. I'm more interested in how/where you mounted the switch. Most of their switches aren't momentary switches.
[MENTION=78273]Jeremy556[/MENTION] What model winch is this from? I am more interested in a panel switch.
I put the plug for the wired remote in the engine bay. I really don't see any reason to run wires into the cab. Reaching down to the dash while you're trying to drive and manage a winching situation is not convenient. With an automatic transmission- it's doable, but it's just not where you want to run a winch from. A wireless controller with a plug in the engine bay is an easy and convenient way to go. I would not remote the solenoids though. Leave those on the winch. Just remote the switching. Inside that box you see is a fuse block with a couple fuses, a master relay and a master on/off rocker switch and a plug for the wired remote on top.
If you wanted to get really sexy with your install, put a switched interrupt of the volume button on the steering wheel and use that as your in/out control.
[MENTION=118321]Jetboy[/MENTION]: YES! This!! Someone help me out with the electrical wiring! Could you use the rear window button instead? Window Down to Winch Out; Window Up to Winch In...
Keep in mind the more crap you add to the system and you add that many more things to fail.
[MENTION=131276]adrtoy[/MENTION]: I'm an engineer, so if it's not broken, it's not complicated enough...:cheers:
[MENTION=137555]Sleeter[/MENTION]: I like that idea, but how are you operating the winch in and out?
So the basic idea is this: You want to use a double pole double throw relay. You'd then need to choose where to tie into the factory wiring. To do this the right way, you would then buy an OEM male and female plug end for an OEM plug connection. You would disconnect the OEM plug and install your interrupt circuit in the middle. Most likely - depending on where you put it - you would solder in most of the wires so they are just a direct jump through to the other side of the plug. The only 2 wires you want to interrupt are the up and down buttons.
So, now we imagine you've got the up and down buttons isolated. The next step is to use the double pole double throw relay. You could also use 2 separate relays, but this is cleaner. What you need then is to wire the hot side of the wire you've interrupted to the common pole of the relay on each side. So "Up" to com1 and "down" to com2. Then you need the other side of the OEM wiring that will continue the normal signal - the other part of the wire you've tapped into - wired into the NC pole on each respective side. That stands for Normally Closed. The default position is to operate normally by passing the signal through.
You will need a toggle switch for on/off of the interrupt system. This will be wired to the coil terminal ends. So ground to coil terminal 1. Coil Terminal 2 to your switch. Switch to fuse to 12v power supply. The result is - turn on the switch, the relay throws.
The NO "Normally Open" post during the default state will do nothing. You roll you window up/down and the window goes up down. BUT when you throw the relay via the toggle switch it will now open the circuit that would have been normally closed (it disconnects the circuit to the window) and closes the circuit from com1 and com2 to NO1 and NO2. Those are now live with the signal from the window switch. You would then wire from NO1 and NO2 to your relays that control your winch in/out functions.
Hope that makes sense.
It's not worth the effort when a wireless relay is $15 on Amazon. But that's how I would go about doing it.
I do use a system like this on my FJ40 because it has no key for ignition. It's just a set of switches on the dash. I use a special circuit I designed as an ignition interrupt so that you must have a couple dash switches fan/lights etc. in the correct position before the ignition circuit will function. Otherwise they just act as pass through. If you don't get the sequence correct it will short a fuseable link at the distributor. If you aren't really damned handy with cars or 100 years old you wouldn't know what a fuseable link even is. And you sure as heck won't figure out how to make it run no matter how you try to hotwire it. It's a low tech theft deterrent. Works essentially on the same principle.
The relays are about $5. The biggest cost will be the OEM plug ends.
[MENTION=137555]Sleeter[/MENTION]: I like that idea, but how are you operating the winch in and out?[/QUOTE]
Wireless remote- IMHO way better than a hard wired control in the cab. Best option would be to have both a hard wired and wireless.
Wireless Winch Controller
Does anyone know of a rocker switch that fits in the OEM holes and look more OEM than the switches from OTRATTW?
Check out the NSA option from Trail Toys. [MENTION=137995]SMKYTXN[/MENTION] Trail Toys
Its a great solution to hook up all of your electrical accessories. Use 2 buttons on the remote for wince in and wince out. That way you are not having to buy expensive wince remotes that only serve 1 purpose. And the biggest advantage is not having to run wires into the cab and cut up your dash for switches.
DionicioLives
