Window Roll-up Module
Scotty_T
Does anyone here know how to incorperate a window rollup module into the factory keyless system, as far as the activation wiring goes?
i know if i hook it up to my lock wire anytime i go to lock the doors it will roll the windows up, so that is not an option, any suggestions?
Well, if you can locate the signal wire for the remote door lock, you could just use an LM555 chip and a transistor or relay to make a simple circuit to roll the window up.
I see you have a 99, do you have the auto up function? Perhaps you can just wire the lock to the auto up wire in the switch.
yes I have auto up, but i already have a window rollup module so thats not an issue, it is just the signal wire to activate it i need to locate
would this work with a relay?
85 - Ground
30 - door lock wire from keyless brain (cut)
87a - to lock switch & window module with a diode on the wire going to the lock switch
87 - to lock switch
86 - Acc Wire
im confusing myself sitting here, would this work?
85 - Ground
30 - door lock wire from locking brain (cut)
87 - to lock switch
86 - Acc Wire
Back to first now, where is that wire, I have searched and have found no answer
Yeah, your first posts were a bit confusing, but now I understand where you are stuck. I have looked for the remote receiver module, but I havn't been able to find it. I dug through the parts diagrams and the FSM, but never found any mention of it. I wanted to tap into the rear window roll-down wire and use it for a trigger for my auto up circuitry.
This would be cool as well when it is hot as hell, if we could figure out how to make it go down, about 10 minutes before you leave work.
sorry, i was trying to find a way to word it where it made sense, according to the local yota dealership the keyless module is incorperated into the fuse box, this could be fun....the wires i should look for are either a red/white or a red, time to break out the multimeter....
Ambrose67
