Windows fogging up
Mark Elliott
The other day, my windows started fogging up but the heater was still pumping out a lot of heat. I didn't do anything different. It was all of a sudden. Anyone have anything similar happen?
You might also have a look to see whether your recirculation air button was switched on...if so then switch it to outside air (which tends to be a bit dryer). That used to work a treat on my 3rd Gen but i haven't had cause to try it out in the 4th Gen yet.
-Identify source of excessive moisture...did you take a shower and hop in the truck?
-Fresh Air Mode
-Turn on the A/C
http://www.homedepot.com/h_d1/N-5yc1vZ1xkx/R-100625651/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Not to get off topic but my 4Runner has this awful musty smell when I route warm air through the console vents. I've been to the dealership for it twice- the first time they just replaced the cabin filter, the second time they supposedly ran some ozone machine through the HVAC system for a couple of hours, but it always comes back.
My question is, anyone know where could I introduce Jeff's Damprid packets to the HVAC ducting?
Replace your cabin filter. (if so equiped)
Heater core?
Is it all the windows or just the windshield/front of side windows?
Is the fog plain water or is it a little oily and/or sweet smelling?
A very small leak in the heater core could be leaking antifreeze and causing the windows to fog.
Another possibility (not specific to a 4Runner...and may not even apply to a 4Runner) is a blocked drain which is allowing water to accumulate in the vents and the heater then vaporizes it.
Crookedcat
