Hey guys,
A little background. About 2 months ago I was driving and at a stop sign going up hill. When I started to go from a stop in 1st uphill there was a VERY loud boom. I wasn't able to drive in 2wd or 4hi and limped back to the house I had just come from in 4lo. I assumed it was the splines on my passenger side axle shaft blowing off as this had happened in 2013. Previously in 2013 I had a bend axle housing and it ended up blowing out the splines on that same axle shaft. I replaced axle shaft not knowing the housing was bent. Fast forward about 2 weeks and determined based on some things going on the axle housing was bent. Replaced that and reinstalled the new axle shaft. that axle shaft had already started to show some wear on the end of the splines.
So after this recent boom 2 months ago I ordered 2 chromoly axle shafts and went ahead and swapped them both out with new bearings etc. Bled my brakes today after work and got in to take her for a test spin and nothing. Same as right after the boom. No 2wd or 4hi only can move in 4lo. Revs freely in any configuration and drives normally albeit with no rear wheels in 4lo. I'm now thinking this most recent boom wasn't the axle splines. It seemed much louder than the first time it happened although there is no way for me to actually verify that.
The drive shaft spins as it would if I was just sitting there not in gear. I'm mechanically inclined but by no means a master at diagnosing things of this nature. Anyone have an ideas?
