won't start...clicking noise
rpearlberg
2001 4Runner woulnd't start this morning. makes a continuous clicking while turning the key. some of the dash lights come on, no radio.
Battery?
Starter?
Something else?
Battery. If it's trying, and failing, there's just not enough power. Easy test? Boost it.
That still doesn't tell you if it's a weak battery failing due to age or abuse or a weak battery due to a non-performing charging system. It could be either--or both, because bad alternator can kill a battery.
You should:
Charge and load test the battery.
If good, or once it's replaced if bad, verify if battery voltage is 13.5-14.5 volts with engine running, showing a good charging system.
I'm gonna go with starter contacts... I don't think you would even get a click with a dead battery.
Not accurate.
Not to say it couldn't be contacts on either end, but a bad or dead-enough battery will cause clicking at the starter.
I would start by trying to clean the start contacts. I had the exact same issue. I could turn it over and it would only click and then all of a sudden it would start. Pull the contacts ensure they are clean and not corroded. After a little sanding put a little grease (for electric contacts) and trying starting her up should correct the issue.
JM
+1
Need to verify battery voltage and charging voltage too.
If everything checks out its time for a starter rebuild. The contact in the starter solenoid (the single klick) when energized puts battery voltage to the starter brushes.
Also get one of these or something similar. It takes all the guess work out of the charging system.
I had something similar happen to my Jeep. Turned out the battery was fine but my positive terminal cable was a corred POS. Scrubbed the terminal and replaced the cable and it started up great. Just wasn't getting enough juice.
Don't over think things. Never go full geardo on an issue. Think easy first. It sounds like you battery is dead.
Jump the truck. Drive to any auto parts store. Ask them to test the battery for you/check the age of the battery. If its old and dead buy a new one. Have them install it and remove/discard your old one.
Should be good to go.
Directed at who?
Well since you asked, I'll use your post as an example.
+1
I highlighted two things. Which are condemning the starter contacts, and explaining the contacts. Good info, but I don't think they are relevant to the OP's problem. Key thing the OP said below.
Not all the lights, NO RADIO. Just not a starter contact issue. It's a low voltage issue. Just sayin'
:peep:
That's why I added to check the charging and battery. First. Then look at starter.
Thank you for pointing it out rather than sit in the sidelines and be a critic.
But there are as many views on engine won't start as there are oil experts. Some people can't even say it klicks.
Order of operations is always important. Of course start with the simple things and progress, I just think alot of folks have had this exact issue and can pin point a diagnosis based on the given symptoms...
With that said, thanks to this forum I just completed replacement of the starter contacts on my new to me 2000 5speed, 4x4 when I got the dreaded click:...no start. click:...no start.... on my first outing no less!
Turns out removing the starter is super simple on a manual trans. I did everything on my back from just behind the front sway bar. I disconnected the pushclip harness and 12mm nut under a press-on plastic sheath for the power cable, the 2 14mm nuts holding the starter on were easily accessible and it dropped right out from behind aforementioned sway bar. No finagling or bending brake lines in the fender well. And the best thing is I did it without jacking up the car or removing a wheel!
Thanks everyone, this is what I did. All is good now.
Mike Sargent
