Would you guys with the Pro be interested in a levelling spring?
I am as I mentioned in the other thread. Specifically, for the 2019 PRO. The suspension is completely different from previous year PRO models.
I certainly would be interested. It’s so annoying that the Pro sits an inch higher in the the front than other trims but it is still 2” lower than the rear!
Ryan, aren't the FJ TRD springs an inch higher when installed on the 4Runner?
You'll get closer to 2" of lift with those springs on a TRD Pro 4runner. They are 1" longer then the Pro springs and 600#. Pretty much the same spring that the Bilstein 6112s come with. I have a set of those about to go on my Pro.
Would it be possible for you to make a 15" long x 3" ID x 600lb coil spring? This is for the FJ TRD Bilstein 6112 that originally came with 14" long x 580lb springs. I'm looking to gain an additional 1" to 2" of lift and I don't want to use spacers or a heavier spring to compromise the ride.
I'd love for you guys to make the pro springs with a higher spring/lb rating. I'm getting a full front bumper replacement and I want to keep it level.
Just get a 13"x3" 600# coilover spring you have exactly what you are asking for.
