WTB: 2003 4runner V8 limited Front Sway bar bushings brackets
cyber_ecco
Looking for a set of front sway bar brackets from a 4th gen V8 4runner Limited. Looking for the stock brackets. Left and right. Let me know if you have a set lying around and want to sell. Need shipped to Washington zip 98230. Or may be able to pick up in Seattle area. Thanks.
Sent from my SM-G950W using Tapatalk
Why not just go with an aftermarket one?
https://www.amazon.com/Prothane-19-1146-BL-Universal-Bushing-Bracket/dp/B003870YF8
These came with brackets when I bought them, might be easiest just to buy these to replace your existing.
I have those currently...not sure if it's because I live in the North West where we get a ton of rain, but I seem to have to re grease them 2-3 times a year to prevent noise. It's easy, but kind of a pain because I have to remove the skid plate every time to do it. I'm also using the proper specialty grease for those bushings. Want to just go back to stock rubber ones.
Makes sense! Just wanted to make sure you weren't missing out on an easy solution. I actually have the stock bushings I planned on taking off in favor of these. I ordered front and rear and only the rears showed up by the time I was ready to install so the fronts are still in a box. If the weather isn't too hot I might install them this weekend at which point you could have my old brackets/bushings.
Sounds great...send me a PM when it's available. I'm not in a rush as I still have those Prothane ones on right now and I greased them a month ago. Thanks!
erinobr2000
