www.autolumination.com HVAC part numbers?
I'm not an LED guy, but I just went through the process of changing out of couple of burned out incandescent HVAC control backlights, so I might be able to provide a little information. The original part# is 90010-09015, which is a long neo3 wedge with an 8mm base width. Looking at this website, it looks like they sell multiple versions that they refer to as Type A (T3) LED that should do the trick. They're found about halfway down this page: http://www.autolumination.com/74.htm
With that said, I've always wondered how the short LED neo-wedges can replace the long incandescent neo-wedges ...
I'm not an LED guy, but I just went through the process of changing out of couple of burned out incandescent HVAC control backlights, so I might be able to provide a little information. The original part# is 90010-09015, which is a long neo3 wedge with an 8mm base width. Looking at this website, it looks like they sell multiple versions that they refer to as Type A (T3) LED that should do the trick. They're found about halfway down this page: Instrument Panel Gauge Dashboard Colored Led Bulbs Lights Lamps
ok. dumb question. so if I buy these bulbs for all my HVAC lighting do they just plug in like the factory bulbs? and how many do I need? I am about to get my dash replaced so they can put them in at the same time I was hoping. thanks?
Should be a direct fit replacement. I only needed 2 for my 06 Sport, but it's my understanding that Limiteds require 3 ....
utkrstam
