XenonDepot HID vs LED, initial photo. (Pics reposted)
Hi,
Yes, you will need to drill a hole in the dust cover that covers up the back of the headlights. The XenonDepot HID kits will come with a grommet that will help you re-seal the housing though.
Polarity - Here is a quick vid showing how to reverse the polarity on an H11 connector.
https://www.youtube.com/watch?v=txQx_kgGjJY
Steve
Hi Steve, I just got around to installing my extreme kit. I plugged the ballasts in and reversed the polarity, but my headlights will not turn on.
i did not use any relays, just the ballast and bulbs. any idea on what might be wrong? this is a '15 btw.
Edit: I put the polarity back to normal and they are working fine now.
phx4rnr: Glad to you got it working. I would always install the components as is, if the light comes on you don't have to bother reversing polarity.
John
I used the relays just because they were there. Can't hurt, right?
No reversing of polarity was needed with mine.
These are soooo much better than stock. It's not even a contest. (Xtreme HID, 5,000K)
I used double sided tape to mount the ballasts and relays. Everything else is zip tied.
Use a 1" paddle bit to make the hole in the cover. Takes about 30 seconds each.
I didn't use the relay harness and did not have to reverse the polarity on my 2015 model for the HID low beam kit.
I went with the LED's for the high beam and there was a relay included with it as well. I hooked up the relay & the LED's wouldn't fire up. Once, I removed the relay harness the LED's fired right up. Is there a drawback to not using the relay harness for the LED highs?
EDIT:
I commented on a really old post, and therefore deleted what I put here initially because someone already responded with the same information.
Stupidest post in entire thread. Tomorrow, Landy will criticize someone for not searching.
:bash:
I went to this thread thinking I had gone to the newest page. I responded to a post that had already been answered so edited the text to what you see there. I needed some coffee obviously.
It looks like the fog lights use the same H11 bulbs as the low beam. I see a lot of people here have gone with LEDs for the fog lights. Any advantage/disadvantage to these over the HID? Install difficulty, durability, etc.?
Also, since there is a nice sale on XD's website for today, I want to order some LED turn signal bulbs for the front as well. Would I just swap these in for the existing turn signal bulbs, and would everything work? One of my previous vehicles needed some resistors to be tapped into the wiring harness.
7443 LED Philips Bulb | W21/5W LED bulb | Philips 7443 Vision bulb
When adding it to the cart it has two options (one with CANBUS)- is that what I would get? And is that built in to the bulb or is it a separate item that needs to be spliced in?
Sorry for the late reply guys, but I just saw this thread.
[MENTION=60898]Paragon1[/MENTION] - Thank you so much for the kind words. I'm glad that you're happy with the H11 HID kit. You will notice that the Philips 4300k bulbs will color shift after approximately 100 hours. They will reach color temperatures of roughly 4700k once they do.
The pictures you posted certainly show quite a difference in the light output.... Although, The HIDs really look that yellow compared to the LEDs... Did you find that the case in "real-life," or is more of a camera thing?
[MENTION=56425]etc.[/MENTION] - Enjoy your new lights :)
[MENTION=3054]Lexusbstrdchild[/MENTION] - Thanks for the feedback! It's always nice when a member can comment on a product after they've had it installed for several years :)
[MENTION=125870]stamonkey[/MENTION] - The whine is perfectly normal. It will subside considerably once the ballasts warm up.
Regards,
Steve
You can always opt for the more expensive 5000k bulbs that color shift a bit less. (google, I think TRS sells a few). They will retail the "blue" band a bit more--but for the genuine "flicker" that comes from select projectors with clear lenses, a retrofit is required. (heavy blue band right at the cutoff from projectors like Acura RDX/Lexus R330/Porsche/s2000).
If you actually go off-road a lot, specifically involving water crossings, you also want to pay attention to where you mount the ballasts. I would highly recommend either buying potted (open up the ballast, and seal the electronics with a goop/membrane) ballasts, or finding a local retrofitter to open them up, pour in the goop, and put it all back together.
HIDplanet will find you a local retrofitter able to do this.
commented on a really old post, lol.
Ahhhh.....no he didn't. This thread isn't old at all.
And who gives an actual **** if he does comment on an old thread.
He used the search function and kept the right information in the right thread.
In other words, he did exactly what he was supposed to do.
wayblom
