XREAS Lift Question
CraigRoberts
I was thinking about ordering the Toytec BOSS for my '10 Limited.
When installing and using the no-compression method, do I need to put all four corners on jacks because of the XREAS, or is it still just the opposite corner? I'm not grokking what happens to the system when you disconnect just one corner.
Fronts up for front and back for the back. Use good jack stands but you don't need all 4 corners up at the same time to do it. You are going to disconnect the whole XREAS anyway and remove it so it isn't a big deal.
TerryNap61
