BlkKnight
I've seen several discussions about carrying canoes, so I thought I'd describe the equipment I chose for my 2013 4Runner. I have a Mad River Adventure 14 canoe, which is 14' long and weighs 75 lb. I wanted to be able to load it single handedly, so I researched various load assist devices and settled on the Yakima ShowBoat with 66" bars along with Yakima KeelOvers to hold the canoe.
The ShowBoat is a roller that can be used with various length bars to obtain the necessary extension to clear the rear spoiler. I didn't want to rest a 75 lb boat directly on the spoiler. When using the ShowBoat with a canoe, the instructions state that the bars should be mounted below your crossbars. This won't work on my 4Runner due to the shark fin antenna. I first looked into mounting the ShowBoat on top of the factory crossbars, but that still didn't provide the clearance I needed to get over the shark fin. So I added Thule 53" AeroBlades for the extra height and mounted the ShowBoat on top. I have the AeroBlades positioned at maximum spread in order to best support the canoe.
When the canoe is loaded, the front of the boat rests on the front KeelOvers. Due to mounting the ShowBoat on top of the AeroBlades to avoid the shark fin, the rear of the canoe doesn't rest directly on the rear KeelOvers. Instead, it rests on the ShowBoat and the rear KeelOvers stick up just enough to keep the canoe from sliding sideways. The ShowBoat roller has an angle to it and can be pointed either up or down when mounting it. The instructions say to point it up for kayaks and down for canoes. I chose down not because of the instructions, but because the rear of the canoe is resting on it. The roller bracket flexes a bit during loading, so I didn't want it to be flexed the entire time the canoe was strapped down. When the ShowBoat is extended, I have a stable loading platform above the rear spoiler. When it's retracted, I have 1-2 inches of clearance when the rear lift gate is fully opened.
The 66" bars on which the ShowBoat is attached stick out over the sunroof when fully retracted. I mounted the ShowBoat's bars centered with about 20" separation so they are positioned within the center of the canoe and don't interfere with the front KeelOvers when retracted.
Regarding noise, I've been very pleased with the Thule AeroBlades. They are extremely quiet with nothing mounted. Once I add the ShowBoat and its forward pointing bars, I get a lot more wind noise and a whistle.
Hope this info helps someone else who is also looking to carry a canoe or kayak.
-BK
-BK
