chaz
ive used deep cycle batteries for at least 14 years, this diehard is more than most people need, myself included) if they dont have high power amps, winches, fridges,shorts,extremely cold winter, or anything than causes a drain.the good thing about deep cycle is it can be drained way down, then recharged, over & over again & still maintain the charge. where as a reg. battery wont hold its charge after its drained too far down even 1 time, (short in system, radio or lights left on, winching,etc.) then u need a new one. u wont have that problem with a deep cycle battery.the discharge/recharge can be done over & over again. lots of guys go with dual batteries, but this one is fairly powerful with large reserve so some might not have to go the dual route. the odyssey 1700, or the yellow or blue (pretty much the same thing but with different terminals) top optima might be a better choice for you. the only drawbacks are they can be much heavier , sometimes guys also upgrade the battery wires at the sametime, & they cost alot more, but at least u know if its ever accidently drained, its still good.i had this in my jeep that i sold,& saw that it just fit , so i thought i try it, i have no problems with this it but it is very heavy & a tight fit, so i might switch to the 1700 or a yellow d35 optima & use this as a backup.
