cpark_12
I've held off on posting this as I've been doing all the research I can, but I haven't found anything.
So, the other day I went down the road to cycle my 4LO and Center Diff Lock like I normally do about once a week. I went off road, put it in neutral, switched to 4LO, everything went smooth and it locked in in a second or two. Good! So, I pushed the CDL and it locked in in about a second or so also. Everything is good! So I climb a hill, drive around in the mud for a bit, then I throw it in neutral and unlock the CDL, it unlocked just fine. I put it back in 4HI and this is where the problem starts...
I hear the actuator shift the transfer case into 4HI, but the 4LO light is still flashing on the dash. Well, I turn the switch back to 4LO and nothing...The light stays lit up like it is in 4LO, but it definitely was not in 4LO, the actuator motor did nothing. So I turn the switch back to 4HI, and I still hear nothing, but the 4LO light starts blinking again, but never goes off. So I drive a little to make sure it's in 4HI and it is, so I keep cycling the switch to see if I can get anywhere. It's like the computer thinks the truck is in 4LO, but it's not! Well, I drive home slowish, just to make sure it doesn't jump into 4LO, and it doesn't.
When I got home, I got underneath the truck while my wife was in the driver's seat and had her turn the switch to see if I could hear anything going on, but nothing. I could hear a faint beep when she put it into 4HI, but the actuator wasn't doing anything. I took a rubber mallet to it, I loosened the bolts so it would come out about 1/8" or so and hit it some more. It wasn't budging at all. I checked the connections and everything looks good, but I haven't put a meter on them yet.
I've searched the internet for this specific problem, but I haven't seen it. I've seen where it won't go into 4LO at all, or where it gets stuck in 4LO, but I've never seen where it's in 4HI, but the computer thinks it's in 4LO.
I'm hoping it's just a bad wire, or a blown fuse, or even the 4WD module. If it is the actuator, I can't see how! I cycle 4LO and the CDL at least 3-4 times a month if not more, and it's never given me a bit of a problem. I figured it would take a little longer to lock in, or something to that nature if it was going bad.
So, my question is: Has anyone else experienced this? If so, any pointers on how to go about fixing it? Any way to get the computer to see it's in 4HI so I can actually drive it?!
Also, does anyone have a wiring schematic for the 4WD system? Does the switch tell the 4WD module to tell the actuator to go from 4HI to 4LO and vice versa, or does the switch tell the actuator then the actuator tell the 4WD module to tell the computer where it's at?
Thanks to anyone that reads this whole post!!!:thanks:
