Your favorite tools for wrenching / tech tools for special applications
I had a bunch of mix & match 1/2" sockets & wrenches of varying quality, some were 12pt. :-(
Last Aug my awesome GF got me this for my B-Day. :humble:
I saw a video and the guy said to spool the sockets on a regular copper electrical wire in rising size order and then twist tie the ends. Way less space. So I tried it. Seems to work way better than randomly throwing them in the tool bag.
Like having a well made and powerful Portable Car Jump Starter / at fraction of NOCO Genius price.
- got one for Xmas & used it 3 times already / easy to use
a) boost John Deere 318 tractor garden with snow blower / 18HP Onan
b) boost Silverado 4x4 / 5.7L gas
c) boost 2000 4Runner, to get to store / and replaced old battery with an AGM one
^^ Remaining charge is still 96%...so extremely good reserve capacity.
GOOLOO 1000A Peak 20800mAh Portable Car Jump Starter
(Up to 8.0L Gas, 6.0L Diesel Engine) 12V Auto Battery Booster
- Phone Charger Power Pack Built-in LED Light and Smart Protection
https://www.amazon.com/GOOLOO-20800mAh-Portable-Starter-Protection/dp/B06XY35D93
- priced on Amazon.com a few months ago @ $99.99 US$ minus 15% off / a month ago it was as low as $69.99 US$
^^ Excellent value, currently out of stock in USA, but found on Canadian Amazon (.ca).
Back when I was in college my girlfriend went to Sears and got the 350 piece Craftsman set for mine. I was stoked, and gave more attention to them than her..:love: Still happens to this day....:crazy:
I used to do it this way, twisted ends would hang on stuff and untwist. So I grab some extension springs diff dia for 1/4" 3/8" 1/2" drive. Cut to length for the number of sockets you want in that bunch, 1/2" drive I put 4 per spring, 1/4" 8 per. I put a flat washer on one end as a stop, a mini carabiner on other end, they can be daisy chained also.
I think I get it , but could put up a photo so I can match my mental image with reality. I found the magnetic plastic socket holder at Lowe’s for $10 and bought two. Here is my top drawer photo
Can't at the moment, toolbox is 7500 miles away had to go to work for a bit.
Think of it like putting a key on a split ring, a split ring can be used in place of washer. Bend a couple end coils of spring at a right angle to body of spring put split ring on. Cut the spring to length for number of sockets you want on that string, bend couple end coils attach carabiner. You don't put any tension on spring, just enough length to install carabiner. Hopefully this helps. Works well for trail bag, not something I would use in shop box, your box works for me.
Ordered this on Monday night from a place in the UK. And got it this afternoon. Can’t wait to shoot some color through my new mini gun this weekend. It’s an ANI R150 with 1.0mm tip. Got excellent reviews and is significantly cheaper than similar ones from the big names. Also the regulator first impressions blow my DeVilbiss ones away and I haven’t even used it yet.
Snap on ratchets 1/4, 3/8, 1/2
Dewalt 20v brushless 3/8 - 1/2 impact gun
(Yes they are stronger than snap on I have both)
Snap on 1/4 14.4v impact gun and ratchet
Snap on 3/8 14.4v impact ratchet
And snap on wobble plus extensions.
All my daily go to tools.
Nice gift! I'm starting to love Tekton tools. I got a great set of their 3/8" drive sockets and ratchet for Christmas.
Ok, new suggestion for a specialty tool which could save your life...
The Vise Grip Locking Wrench has saved me several times with rusted and partly rounded bolts. It just saved my @$$ with a frozen bleeder screw on my front caliper. It was beginning to round off as I pulled. I stopped turning with my flare nut wrench and grabbed the Vise Grip Wrench. It turned the bleeder screw to break it free and I finished the job.
https://www.amazon.com/Vise-Grip-Lo...TF8&qid=1524293801&sr=1-22&keywords=vise+grip
haha, that 1/2" set was for my b-day & I also got the matching 3/8" for Christmas from her too! It's nice having everything in one case. I've done a lot of research over the last few years & Tekton looks to me to be the best quality for the money out there. It's all I buy now. Most, if not all of the cheap stuff is made in China where as the Tekton is made in Taiwan to a higher quality. Even the not so cheap Craftsman, Kobalt & Huskey are all made in China. Forget about the Harbor Freight junk. I do have 1/2" Impact sockets from Stanley that were cheap but awesome though. I've put them through NE rust removal hell & they've been rock solid with my Dewalt 1/2" impact.
crank and camshaft holding tool
ive always loved air tools but for the last couple of years ive just been using cordless tools mostly dewalt and milwakee but by far my favorite specialty tool is this tool for loosening and tightening crank shaft and cam shaft pulley bolts. The "holder" also holds drive line flanges such as diff, transfer, trans and drive shaft.
Is that something you made?
it's a sst toyota tool that I bought about 12 years back.this tool is a beast it's a toyota tool comes with multiple bolt lengths. and I can do the timing belt by my self in about 2 hours.
new favorite tool. Tracing electrical circuits and testing devices is so much easier now - Power Probe. You can check if a wire is hot, positive, negative, provide + power to energize something, provide ground to something. What a great tool for electrical work on rigs..
If you want to stock up on gear oil now is the time to do it. Home Depot has Lucas 75-90W on clearance for $3.53 a bottle. Get em while you can....
Recommend a welding shield
I'm in the market for an upgraded welding shield, can anyone recommend any auto darling ones they like in the $50-$75 range? I know about the hf ones, but wanted see if y'all had any hidden jems or wether I should increase my budget? I weld a few times a month on a flux cure Lincoln, but I'm planing on Getting gas for it soon. Thanks
2001ATL
