ANTMAN'S Thread
Antman
Antman's 'Runner: 2011 SR5 Premium 4x4/Magnetic Gray Metallic
OVER 150,000 Miles!!! (SOLD)
Welcome to my build thread!
March 2013 T4ROTM Winner!!
Links to Mods in this thread, and others I've done...
**COBRA 75CB INSTALL
**FRONT AIRDAM REMOVAL
**AIRLIFT 1000 INSTALL (SCROLL DOWN)
**GOBI BIKE MOUNTS
**AIRBOX MOD
**INDEPENDENT FOGLIGHT MOD
**12V OUTLET MOD
**DADDY'S TRUCK MOD :)
**SPIDERTRAX
**PLASTIDIP SR5 WHEELS
**REAR WHEELWELL STORAGE (BRUTE FORCE METHOD)
**REAR STORAGE SHELF- made from an old bed??????
**TAILGATER CUPHOLDERS
**REAR STORAGE AREA/FLAT CARGO FLOOR
**DRL (Daytime running Light) MOD
**DRL + FOGLIGHT MOD (Complete madness, this one)
** POWERED SUBWOOFER INSTALL: HOW-TO
** N-FAB STEPS INSTALLED- CUT ROCKER PANELS: HOW-TO
** UNDERHOOD ACCESSORY FUSE BOX INSTALL
** Carroll Shelby Tribute
** ONBOARD AIR COMPRESSOR INSTALL
** UNDERHOOD LED LIGHTS
** OIL CHANGE TUTORIAL- 5th GEN SPECIFIC
** TRAIL EDITION HOOD SWAP
** ANTMAN EYEBROWS :naughty:
** ANTMAN PORCHLIGHT (Outside mounted switch for rack lights)
**THE $25 AWNING PROJECT
**RIGID INDUSTRIES 6" SPECTER LED'S ON THE GOBI
**SCANGUAGE-FLUSH MOUNT IN O/H CONSOLE
**RIGID INDUSTRIES 10" HYBRID SPOT ON THE GOBI
**hIdePOD MOD
**WHEELS/TIRES- LEVEL 8 GUARDIANS/DURATRACS
**PLASTIDIP DOOR HANDLES and the child-lock dilemma...
**DOOR FLASHLIGHT HOLDER
**TRAIL EDITION SKID PLATE INSTALL
**AWNING LED LIGHT SETUP
**BILSTEIN 5100's ALL THE WAY AROUND (2.5" lift) & SAW 1.5" REAR COILS
**INEXPENSIVE SOUND DEADENER
**CARGO AREA VOLTMETER
**FIRE EXTINGUISHER MOUNT
**SECURITY SYSTEM ANTI-BEEP SWITCH
**EXPEDITION STYLE STORAGE BOX, SLEEPING PLATFORM WITH PULLOUT TABLE
**INSIDE REAR HATCH RELEASE BUTTON
**ARB FRIDGE
**DUAL BATTERY SETUP
**BALL MOUNT CB ANTENNA/MIDLAND CB FLUSH MOUNT IN CONSOLE
**ROCKY ROAD SUPERSLIDERS (STRIPPED /REPAINTED) AND MURDERED-OUT ROCKERS...
**Chuck
**REAR GARNISH LED MARKER LIGHTS
**2016 TE REAR BUMPER INSTALL WITH RIGID FLUSHMOUNT REVERSE LIGHTS
**REPLACEMENT FRONT BUMPER/BEDLINER BUMPER
**PARKING SENSOR INSTALL REAR TE GARNISH
**NEW TIRES @115,000 MILES- BFG ATKO2 - 285/70R17E
**TRIMMED FRONT BUMPER (INCREASED CLEARANCE)
**CONSOLE ARMREST CUPHOLDER
**POWER FOLDING JDM/ADM MIRRORS- HOW TO
(**** = Mods documented by Sp8ball in his thread that I had already done on my 4Runner)
****TOYTEC TOP SPACER INSTALL
****HOW TO MAKE INTERIOR LED's
****DOOR PANEL REMOVAL
****INTERIOR DOOR HANDLE LED's
****CUPHOLDER LED's
****REARVIEW CAMERA MOD
**And here's the REARVIEW MOD FOR PEOPLE WITH FACTORY NAV... :)
****My workshop/garage!****
ANTMAN Organized Events
** Sandy Point St Park- September 2011
** The Cove Campground- October 2012
** The Cove Campground (2)- October 2013
** The Cove Campground (3)- October 2014
** The Cove Campground (4)- October 2015
**The Cove Campground (5)- October 2016
Seattlemike- Gone but not forgotten.:guitar3:
:fishing: ( I love to fish, just wanted to write that in here somewhere)
ANTMAN MOD #1
Here's my Airlift 1000 airbag install.
It's easily the best bang-for-the-buck mod @ $100. The Airbags are very useful- for those who don't know- for preventing rear-end sag under heavy load. I tow a boat regularly, and a 19ft camper (haven't yet), so these were a necessity. Lots of people on here have installed this kit, so what makes mine different? Well- I installed an onboard compressor, and it only cost me $20 bucks. ...
This is the driver's side bag installed in the spring
049.jpg~original
Here you can see where the line exits under the spring perch
052.jpg~original
I installed the compressor in the jack storage area....
042.jpg~original
Looks pretty wierd, huh? I picked up a 12v inflator at Target for $20 on the clearance rack because, well, it was only $20. I planned on using it to inflate the airbags, and I kept it in the cargo area. It was always in the way. I took it apart, and this is what you see. I was able to use the switch, air hose, and the air guage as well from the original plastic case. It's wired to the 12v outlet in the passenger side rear wheelwell.
046.jpg~original
048.jpg~original
The switch, literally, just plugged into a factory square hole... The guage is on a flexible hose that pushes inside the cover.
045.jpg~original
041.jpg~original
This works VERY well, and everything tucks away nice and neatly behind the jack panel. Since the airbags have a working range between 10-35 PSI, it's not required to work very hard to inflate the system. I have used this probably 15-20 times, and it brings a smile to my face every time because I think it's kinda cool.
Maybe not for everyone, but then again, a lot of my mods are that way!
Dude, I've been paying attention to what you and Sp8ball have been doing for a while. Must say that you're quite the guru with this stuff. Awesome job.
Question
Antman, did you hook up the lines to inflate at the same time or is each side independent?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p>
Just a little something for Sp8 and Antman. Keep up the awesome mods.
**edit** Well I guess this isn't working. It was showing last night when I did it.
Just in case anyone was wondering, It's the Foo Fighters......My Hero. lol
ANTMAN MOD#2
Here are my Gobi Stealth fork-down bike mounts- ANTMAN style...
I love my Gobi Stealth! I wanted to install some bike mounts on the crossrails, but I will also use the rack to haul stuff like plywood, drywall, etc. The standard Thule fork-down mounts sit on top of the rails, so I would need to remove them to haul big stuff, not an option. Plus they cost quite a bit more than what I came up with.
These are mounts from Performance Bike. They cost $15 a piece, and are pretty well made out of aluminum. Only real issue I have with them is that they can't be locked...
IMG_8422.jpg~original
I fabbed up some backing plates out of 1/4" aluminum, and tapped some holes to accept mounting bolts. This distributes the load over a wider area of the steel mesh. All the hardware- 1/4-20x3/4" Allen bolts, washers, and split-ring lock washers- is stainless steel.
IMG_2163.jpg~original
IMG_6605.jpg~original
The mesh is pretty stout- I can stand up there with only a little flex- but I tried different areas and this corner seems to be the strongest spot. The bikes are very stable, and only flex the metal a tiny bit if you shake them...
IMG_4193-1.png~original
053.jpg~original
054.jpg~original
photo-7.jpg~original
Currently, I am using some high quality flat bungi cords to lock down the rear wheels, but I am looking into some Yakima wheel straps that I will mount up in the future. Will update the post when that happens.
IMG_6443.jpg~original
I've had the bikes on the interstate at 75mph, and also on some curvy roads, and all has been great.
Antman, did you hook up the lines to inflate at the same time or is each side independent?<O:p></O:p>
If you look at the pic with the TRD valve cap, you can see a black plastic plug I installed to cover the hole I made for the second inflation valve. This was just in case I decide to go that route in the future. For now, I'm happy with the one line inflating both bags equally.
Ant,
Can you get a padlock and lock the turn handle to the expanded metal?
ANTMAN MOD#2
I fabbed up some backing plates out of 1/4" aluminum, and tapped some holes to accept mounting bolts. This distributes the load over a wider area of the steel mesh...
053.jpg~original
054.jpg~original
Reata- yeah that padlock's a good idea, but it won't be too practical. Those bikes are waaaay up there! If someone wants to steal my bikes that bad, I figure they need 'em more than me. Now if I see them rolling down the road on my bike- they will get a firsthand view of my airbags as I run their a$$ over!!! Thanks for the idea!
(in my best bugs bunny voice) oh, the travesty! Wait until you get back into singletrack haha! You will be locking it up tighter than Fort Knox! My hitch mounted setup has not one, not two but THREE locks and I live in a very low crime place. I use them mostly when I go riding out of state. My rack has a frame lock, my rack has a locking pin to the receiver and I use a cable lock for the wheels.
I have followed your mods on SP8ball's thread and I think you have done some really cool mods. Keep it up!
ANTMAN MOD #3
DIY Airbox mod. This was the first mod that I posted on this forum (I think), and I pretty much got blasted for it. I have updated the design a little with an aluminum heatshield, and plugged the "ice cream scoop" back into the box...Also added a K&N drop-in filter (please save the crapola about the oil screwing MAF sensors up and all that- been using K&N for 15 yrs, no prob)
Here's the original thread: http://www.toyota-4runner.org/5th-gen-t4rs/84211-diy-airbox-mod.html
You guys weren't very nice! I got a complex and it took me months, months! to get the courage to start my own build thread because of the lashings... :sobbing: Then it came to me- nobody else has the guts to chop up their airbox, or is it that I just like to cut stuff up for no reason....:toilet3:
Whatever- I still like this mod, and maybe someone (?) can benefit from it in some way:
This is a shot of the cutout with the air scoop inserted back into the fenderwell. This should help to channel some air in there...
058.jpg~original
I made a heatshield out of aluminum plate to help -uh- shield some heat... from the intake. The TRD badge was a gift from Sp8Ball ...
057.jpg~original
059.jpg~original
062.jpg~original
I have driven in a few 100 degree days, and didn't notice a real lack in any performance. It sounds great when you get on the throttle- especially when combined with my Magnaflow muffler. That's the main reason I like it. The induction noise reminds me of my built 302 in my '69 Mustang (first car, long gone) VrOOOOOOOOOOOOOOOOOM!!! That's what it sounds like.
Slow clap: BEGIN!
Seriously though. Love it. And I will be using the fork mount idea for the bikes. Please keep up the amazing work.
Dude...this is awesome!
I've had my head so far up my own butt with the baby and work, and I've barely spoken to Antman (well, we text) or gotten on the forum.
And look at this! This thread rocks!:nicethread:
New mod should be posted sometime tomorrow that allows independent fog light control using the factory switch. I've been hesitant to post this for a while because there is one small issue that bugs me...
That's all I'm sayin' for now(the great Nashman69g knows ).:)
That's all I'm sayin' for now(the great Nashman69 knows ).:)
Building the drama...
:hiding:
It shocks his testicles every time he uses the fog lights. lol
