3rd Gen Steering Wheel Swap?
Sooooo, this thread may have gotten stuck in my head for 2 days...... Then I may have done a late night wander on to eBay.... Then I somehow I bought this....:naughty: Guess I will update you all when I get it installed.
And???
I'm sick and tired of the 300k mile sun damaged steering wheel in my 2001...
And???
Done. I posted in "What you did" about this, but since you asked I thought I would add it here. Easy as pie. Just had to cut and swap the airbag wire from the Celica clock spring to the 4r and move my cruise control switch (had to file the new mounting spot with a dremel a little bit to make it fit). It had a small wear spot on top so I added a new leather cover before I put it in. This pic was day 1, I since added a few more stitches to tighten up the cover a bit more. Leather wrap took an hour and a half. Installation and modifications took an hour. Bonus: Sold my old wheel for exactly what I paid for this one.
What a co-incidence.
I found the same Celica wheel on ebay here in the UK, with airbag but no clock spring. I left it with a garage to fit it when the truck was in for a gearbox flush. The garage told me the stock Surf / 4Runner clock spring plugs were incompatible with the airbag on the wheel.
I saw Charlie's (TorqueOfTheD) comment that his Lexus clock spring swapped straight over, so I found a Celica one on aliexpress and that showed up today. But then I also saw what the stock Surf / 4Runner clock spring looks like and they are a different shape in terms of screw fitment.
I was thinking I was screwed and to just offload the wheel, when I wondered if just the plugs could be swapped. Et voila, here's your post. I'll take my Celica clock spring down to them and see if they will just splice the plug to the stock clock spring as you did.
For what it's worth, I believe physically most of the same-era wheels will swap, but it's the clock springs (and their plugs) that dictate whether you can retain the airbag.
Stock clock spring part for Surf/4Runner 3rd gen is 84306-12070 or 84306-35011.
If you search for those on AliExpress.com - Online Shopping for Electronics, Fashion, Home & Garden, Toys & Sports, Automobiles from China. you can get an idea of the shape. 84306-35011 will fit (according to them):
This part fits for following models:
Euro-market:
1997-1997 PASEO EL54
1997-1999 CAMRY (JPP) MCV20,SXV20
1997-1999 CAMRY MCV20,SXV20
1997-1998 PICNIC CXM10,SXM10
1997-1997 RAV4 SXA1#
1997-1997 4RUNNER RZN18#,VZN18#
1997-1998 LAND CRUISER 90 KZJ9#,VZJ9#
General market:
1997-1998 CROWN COMFORT LXS10
1997-1998 TOWNACE/LITEACE SR40
1997-1997 4RUNNER RZN185,VZN185
1997-1998 LAND CRUISER 90 RZJ95,VZJ9#
North American market:
Japanese market:
1997-1997 CORSA/TERCEL EL5#,NL50
1997-1997 COROLLA 2 EL5#,NL50
1997-1998 CYNOS EL5#
1997- CAMRY/VISTA SV4#,CV4#
1997-1998 MARK 2 GX100,JX10#,LX100
1997-1998 CHASER GX100,JZX10#,LX100,SX100
1997-2000 CROWN COMFORT/SED GXS10,LXS11,SXS11,YXS1#
1997-1998 IPSUM CXM10,SXM1#
1997-1998 LITE/TOWNACE NOAH,V CR4#,CR5#,KR4#,SR40,SR50
1997-1997 HILUX SURF KZN185,RZN185,VZN185
1997-1998 LAND CRUISER PRADO KZJ9#,RZJ9#,VZJ9#
Those should be a straight swap and retain your clock spring as the airbag plugs should match.
The Celica clock spring is 84306-52010 if you just want to order this and then use the new Celica plug on your stock clock spring to allow you the Celica wheel above (1999 MY).
Hope this helps!
Saw on instagram
Hey, 2020 here...
I was scrolling through Instagram and came across a guy who he swapped a 2019 Tacoma wheel into his third gen. I was busy and forgot to save the post, so I dint have the details but if I find it I’ll let you know.
Hey, 2020 here...
Would love to see it. I just sold my 2016 and bought a 2002 SR5. Generally I like it better but would be cool to have steering wheel functionality on aftermarket stereo.
Going to have to do some wiring but it can be done. I doubt the airbag systems would match though. Not sure what would be involved in that kind of a change. :/
erinobr2000
