A/C Evaporator Core Replacement
I'm just embedding all the pics here. I'm going to have to do this soon, and will work on a writeup too.
Hey guys, day one on the evaporator core replacement is coming to a close. I'm waiting to pick up the new core tomorrow. I'll post some pics of what I had to do and show where I'm at now. I have pretty much every bolt/screw in a labeled bag.
Removed lower cover under steering wheel
Imgur: The magic of the Internet
Removed metal piece under that
Popped off center console bezels (Ignore extra wires)
Removed rest of center console
Removed Center dash cubby and hvac controls
Removed Center dash bezel
https://imgur.com/wiiiLHv
Removed Radio
https://imgur.com/gEBmMcP
Removed trim around gauges (no bolts)
https://imgur.com/Sp9FTnR
Removed trim piece under glove box, glove box and cubby above glove box (was intimidated by gauges at first)
https://imgur.com/3WQr16j
Finally removed gauges (two bolts at top release wire harness)
https://imgur.com/htARDkN
https://imgur.com/7hetsZY
Next, removed passenger side air vent and took out all bolts holding the actual dash in place so as to get it fully removed
https://imgur.com/Yqu5aAy
Had to get some deep well sockets to release steering column so I could get the dash brace to move.
https://imgur.com/EYFpkQJ
At this point, I was a little frustrated and the pictures are less frequent. I disconnected the fuse box, ecm, and anything else that the large brace was connected to. There are a few bolts on either side that are accessible from the door jam that I removed and/or loosened to help free the brace. There are also brackets going to either side of the trans tunnel that needed to be removed.
After I had some play in the brace, I went around the heater box and evaporator and unbolted anything that was holding them in. I managed to get each of them out finally.
https://imgur.com/EfyyBI7
https://imgur.com/oA9SvLK
https://imgur.com/FGnooHK
https://imgur.com/1RguBgH
The evaporator has screws running down the middle that need to be removed in order to get inside to the core. I had to remove a servo in order to rotate a fin to pull it apart.
https://imgur.com/BNz7xzl
Here is the busted core, which i will be replacing and reassembling tomorrow.
https://imgur.com/cwMUG6y
If there is anything that is unclear or any questions, just let me know. I know that I didn't do the best job documenting the process, but I figured it's a lot better than anything I've been able to find. I'm flying mostly blind on this but it's coming along alright.
~Now I Do not feel so Alone~
Dude - this was traumatic. We just went through ALL OF THIS.
To see my Truck's "Face Off''. Been trying to find information on Internet. Nothing. Looking at all possible problems to AC leak in my 2008 4wd Urban Runner...So, we just Replaced EVERYTHING. Evaporator was the problem. Crazy leaky mess. Amazing what crap Heater Core is. Yeas replaced that - Snaps when you take out.
In process of clipping in Center Console now.
Cold 1st time in two years... Not everything hooked back up, so Temp Control yet to be working. Blows Very Cold only in "LO". Bump up to 65° it blows HOT.
Appreciate you Posting all these. Good for you.
The evaporator core finally failed after years. The dealer replaced the
OEM that failed at 4 years. So after 15 years, I've had two EC fail.
After viewing all the online instructions I took a new EC ($90) to an AC shop and they did the work for $880.
Got the car back in perfect shape.
I've been cool and cold for two weeks. Hope I can get through the summer here in the Bahamas.
2005 4runner with 150,000 miles. :hatsoff:
UPDATE : 5 weeks of Ice cold AC through May 24th.:beer:
this is the evap I bought that was used in my 4runner Amazon.com: Denso 476-0040 A/C Evaporator Core: Automotive
If you are not a mechanic with experience with evaporator core and dash removal, pay the piper on this job.
H.Sikina
