Saker’s Ebony Build
December 14, 2020
Installed Scuba Mod on Rear Differential & Diff Locker
Cut the hole with a hole punch in rubber plug # 90950-01958, inserted fuel line, routed it, removed OEM one-way valve from differential, disconnected the 1/8” breather line from the diff locker, connected those to the fittings on the “tee” .
Parts Used:
(1) 90404-51026 Toyota 1/4" Fuel Line Union
(1) 1/8" NPTF Brass Tee
(1) 1/8 X 1/8 HB Male Adapter (1/8" Hose ID X 1/8" Male NPTF Adapter)
(3) 1/4 X 1/8 HB Male Adapter (1/4" Hose ID X 1/8" Male NPTF Adapter)
(1) 1/8" Brass Pipe Plug
(1) 1/4" Brass Pipe Plug
(1) 2 Port Manifold with Filter
6' of 1/4" Fuel Line
Hose Clamps to fit.
Aluminum Bracket fabricated: I made mine out of a piece of 1/8" thick aluminum cut to size, bead blasted it and marked & drilled the holes.
Brass machine screws, washers (flat and lock) and nuts to attach manifold to bracket.
Mounted in the Bottle Jack Compartment with 1/4” SS cap screw, flat, lock washer and nut.
pnU8TTmLj
pouOWYJXj
pnVDdj2Aj
Parts Used:
Hose Clamps to fit.
:fish2: Looking good...ready for those high water days and almost got her back to her back to Midnight Status :hatsoff:
Happy Holidays my friend!
:cheers:
:cheers:
Thank you sir!!!!!
More stuff coming, it all takes time.
Merry Christmas to you and your family!
December 18, 2020
Installed RSG Sliders
See Link
2010+ Toyota 4Runner Angled Sliders **NO KICK OUT**
pn5Uq1aij
pmCFJsIFj
po14BySsj
pmpeVKCkj
12v Auxiliary Circuit
Saker,
Where did you get the Auxiliary Circuit and what brand is it? How many circuits can be used total?
Thanks!
November 3, 2020
Installed 12V Auxiliary Circuit
UPDATED: November 8, 2020
Powered for current circuits. 1) Engine Compartment Light Mod 2) Raptor Light Mod
pnotGt4Cj
pnPbOzwPj
pnQXIi29j
November 18, 2020
Installed Engine Compartment Light Mod
This is going on my list of must-do mods. I really like it! I can't remember if I have seen that switch on a fire truck or a public works (high-end) utility bed, but that is an awesome application! I'm in the government fleet biz, so I get plenty of ideas... and you applied one I hadn't thought of. Bravo, sir!!
Thank you sir, I hope this helps you !
(Personal: It’s a toss up between these and my old Morimoto 55watt HID’s in my 2014.)
Saker - for the High beam install, was that plug and play, or did it require cutting?
I was hoping maybe the '21 headlights would have an easier install for the high beams...
It took me 6 years to get my mods to this place on my Saker’s Midnight Build.
Except no tint, light bar and no lift/shock replacement yet!
(Donations excepted with gratitude!) :biggrin1:
It's been only 2 months since I took ownership of this one.
Mike Sargent
