The brown truck arrived today with a nice pair of packages that I had been expecting.
Jason @ RSG Off Road hit the nail on the head with a 4-6 wk window for delivery! Thanks [MENTION=152854]JasonRSG[/MENTION]
I ordered his 2010+ Toyota 4Runner Angled Sliders **NO KICK OUT**.They arrived well boxed, well protected....now time for inspection! Unwrapped, inspected, welds are awesome, powder coating is flawless!
Kudos to RSG.
pmCNHDH9j
Prep time for install.
Chased all threads with Kroil & a thread chaser, not a tap. Removed all the frame plugs that were going to be in the way.
Installed them with 2 jack stands for support.
Final install photos:
pn5Uq1aij
pmCFJsIFj
po14BySsj
pmpeVKCkj
I love the way they turned out.....
It was my first time driving on ice on the road today. My SR5 has the Dueler tires stock. I was actually pleasantly surprised by how planted my 4Runner was on the ice in both RWD and 4WD. I don't think I've ever driven something this composed on the ice before. There was even one intersection where I was stopped and on the ice and had to turn left. I gave it more gas than I was giving it up to that point, and it was fine. (I made sure to wait for everybody to pass by.) I think I like these Dueler tires for street use.
Thanks to this forum I was able to fix my driver side automatic window switch. Just replaced the factory battery in my 2017 4R and used a OBDU back up battery to save the millage/radio settings. In doing that it messed up the auto switch programming (just the driver side window). Super easy fix to reprogram (hold switch down until window stops and hold for 10 seconds, do the same on the UP) but not one I would have thought to try.
That's twice this forum has saved the day for me on stupid fixes.
Accessorides remote start installed. Super easy install too. Removing the panels, running the wires, and programming took maybe 15 minutes. 30 spent securing the box and making sure wires were in good spots. Very happy with it.
Nice!! Can we get a pic of the new clean look? And a pic of this hole you're talking about, I'm not entirely sure what you're referring to??
Here you go
The dock here. On this one I reversed the liquid "ramps" raised the cable by 1mm, widened the phone width by .5mm, and added about 40mm to the "rails".
and the new hole since I moved the port inside the console.
Did some searching and there is not much I see to put in that slot, so I'll probably be printing a filler for it.
Here you go
Nice. Do you have a link to that dual usb charger?
Here you go
<Image>
<Image>
Dude that looks sweet!! Great job hiding the wire.
Yeah I think printing a filler would be your best bet... or hell, print a deep angled pocket so you can put a couple pens in there? :noidea:
Pressed a new wheel bearing to repair a bad abs tone ring....(pictured is not the wheel bearing that came off, just an old nfg one I had in the shop that I stole the hub from)
...and then rolled her across the commercial truck scale. 6,200lbs!
What a fat pig &#55357;&#56342;
Oh, my, great idea. Think I'll work on something like that. Thanks for the suggestion.
seltzernator
