Thanks for that video going to do that this week. Also, thanks for fixing my images.
Here is the STL, I'm not a pro, just poking around in tinkercad to make this. Trying to learn Blender now.
Toyota 4Runner OnePlus 6t Dock by laserdemon - Thingiverse
Here is the Tinkercad if you want to play with it in there.
Tinkercad | From mind to design in minutes
I just decided to move the inside bottom wedges to the outside. I was thinking about if a drink spilled into the dock, that version is just asking for "stuff" to build up in. So I moved them to the outside in the next version.
Just got my new 2021 TRD Offroad Premium a few weeks ago, and had to fix one annoyance today. I hated having to reach down and plug in my phone for Android Auto, and it didn't fit in any of the shelves (Oneplus 6t) so I designed and 3d Printed a dock.
Imgur: The magic of the Internet
Actual Install.
Still needs some work, but it does the job. I know its a small addon, but it fixes a problem for me.
I'd love to do something similar, but how is it in real-world use for you? I have a pixel and it's not like the cable would just go into the port via gravity, I'd think you've have to push it down in the holder with some decent force?
Thank you! When I eventually upgrade the head unit to one with android auto support I will tinker around with this design for my phone.
Depends on the tolerances. This version is not perfect, just takes a small push. Most ports take some pressure, not a ton.
As long as both the holder and the cable are secured well enough then a little bit of "force" to push the USB-C in shouldn't be an issue.
(fixed your images so they show up here)
Dude this is sweet!!! Is this up on Thingiverse somewhere? I'd love to remix this for my Pixel 3.
Yes, I was going to say the same thing. [MENTION=626156]laserdemon[/MENTION] the lower panels of the dash pop out super easy and you can hide that wire real simple.
Edit: In this video you can see how easy it is to get inside the center console:
https://www.youtube.com/watch?t=152&v=gdSP5s6tZyI&feature=youtu.be
You may also want to consider a cable with a 90deg lightning plug too (if it'll fit).
First voyage (for me) in the snow today. So far we've got 3" here in northern VA. Got sideways (on purpose) multiple times. Very satisfied with the Toyo AT III's too.
what part of va are you in, im in md and we barely got a dusting
Tossed on the stock running boards back on yesterday before the first snow of the season hit... Figured it would help protect the side of the 4R a bit from all the salt and debris that would get kicked up.
Added Predator steps for the kiddo and clear bra. I think the steps will also save our pant legs this winter and the bolsters long-term.
Yes, the dealer is more expensive but I knew that if I didn't get it done right away it would never happen.
Sent from my HD1905 using Tapatalk
i cracked a milestone of sorts.
im sure there are some here who i am behind, and some that i am ahead of...but at this level, with the only problems being a bad lumbar support (fixed under warranty) and the auto door locks-thing to my front doors...thats pretty great
:thumb:
[MENTION=468417]DaveSki[/MENTION] could you post the link to the canadian bumper on amazon? I looked several different ways and couldn't find it. LOVE THAT LOOK you got!!! And my lower front bumper cover area is kind of jacked up anyways.
My 2011 is pearl white.
Thanks man! Here is the link I ordered from. Arrived pretty darn fast and fit was good.
Amazon.com: Front Bumper Cover Compatible with Toyota 4Runner 10-13 Primed SR5/Trail Model CAPA Certified: Automotive
I ran the cable through the dash to the dock today, looks SO much better. Any suggestions on what to put in that hole I have now? or should I just print a blank?
Threw in the lower shock skids.
Nice!! Can we get a pic of the new clean look? And a pic of this hole you're talking about, I'm not entirely sure what you're referring to??
Mounted 1 side of these panels made by a buddy out here.
Mocked up maxtrax placement on them as well, will probably move the shovel to the same panel and rotopax on the driver side.
Wheel gang.
Jhunt
