Cigarette light fuse
Toymaker
Was in a bind and had to use the cigarette lighter as a power source. I knew it was going to pull too much and after about 10min POOF no power. Does anyone know where the fuse is for that. I was looking around and couldn't find anything. :/
Sent from my HTC One M9 using Tapatalk
Runs off the ACC fuse. If your clock and radio still work, then you fried the fusible link that is built-in to the receptacle. That means a new receptacle or you can DIY a hot wire fix. The how-to is out there if you search....might be on YotaTech. You lose that extra protection, though.
See that L-shaped black wire? That's it.
