Part Number/Size Needed Please - Bolts that fasten Transmission to Engine Block
NEKExplorer
I picked up what I hope is a nice 5VZ-FE from a junkyard yesterday and brought it home on a trailer. I would like to mount it on an engine stand to off some of the stuff they left on it and to replace a few things before I hand it over to be installed by a pro, but the yard did not leave any of the bolts for fastening the tranny to the block (and I wouldn't expect them to). I need the bolts to fasten it to the engine stand.
Anyway, does anybody know the part number for these bolts? I would like to order them directly from Toyota rather than try and figure out the right size and thread pitch and risk damaging threads.
Thanks for any help.
You'll need 3 bolts each per part number
90119-12267
90119-12005
I don't know the bolt diameters and thread pitch.
Maybe someone else can chime in with these. That way you could pick these up at the hardware store.
90119-12267
90119-12005
Those 12s tell you it is M12. Works for washers and nuts, too.
Toyota only uses one pitch for each diameter:
6 mm diameter - 1 mm pitch (iso course) - requires 10 mm wrench to fit head / nut
8 mm diameter - 1.25 mm pitch (iso course) - requires 12 mm wrench to fit head / nut
10 mm diameter - 1.25 mm pitch (iso fine) - requires 14 mm wrench to fit head / nut
12 mm diameter - 1.25 mm pitch (iso other) - requires 17 mm wrench to fit head / nut
14 mm diameter - 1.5 mm pitch (iso fine) - requires 19 mm wrench to fit head / nut
16 mm diameter - 1.5 mm pitch (iso fine) - requires 22 mm wrench to fit head / nut
So M12x1.25.
Unfortunately, length is not so easy.
12x1.25 factory length depends on transmission. But if. You're just using them to install on an engine stand measure and get the best length for the job. Some factory ones are too long, some are too short.
Sent from my JSN-L23 using Tapatalk
Awesome everybody, thanks very much for the info. I can't wait to start stripping stuff off this engine, clean it up and do a couple of jobs on my own before I hand it over to a pro for installation.
Hey I may have some bolts that came out of my 02' part out when I pulled the trans.
LMK if you still need them.
JROTN
So the bolt holes/faceplate on my engine stand will take up 2 1/16 inches or about 54mm of bolt. I am thinking that if I add 50-54mm to whatever the length of the OEM bolt is and buy a 12x1.25 at that length. Anybody know the length of the OEM bolts?
Should I buy grade 8 bolts to make sure the bolts can take the load of the engine? There are only four on my stand. Specs on the motor says it ways 425lbs.
Thanks again
any chance you could tell me how long they are?
it depends on the engine stand. the ones I used were from home depot and they were
M12x1.25x90mm
I have cheapo harbor freight
you need longer/shorter ones depending on your engine stand mount.
<a href="https://imgur.com/rr0usYF"><img src="https://i.imgur.com/rr0usYFl.jpg" title="source: imgur.com" /></a>
I actually made an engine stand out of 2x12's and it almost works better than anything else I have used. a standard sized furniture dolly fitts perfect under it so you can roll the engine around lemon squeeze. unless you need to flip the egine over? the wooden one works better IMO. can leave the flex plate on the egine with the wooden one, can't on the engine stand.
<a href="https://imgur.com/ttYhAUX"><img src="https://i.imgur.com/ttYhAUXl.jpg" title="source: imgur.com" /></a>
I bought the grade 8, 12x1.25x100mm for my engine stand and 150mm to make alignment dowels for install.
I bought the grade 8 cause that’s the only bolts my local hardware store had in 1.25 pitch. I bought the 150mm cause they were the shortest with a section of smooth shank.
drew93023
