Need Help - SRS Codes!
ghs215
Need Help - SRS Codes! --SOLVED--
Ok, T4R Guru(s)
I have the dreaded SRS codes and need help figuring it out.
Past
B1150 - Occupant Detection Malfunction
B1152 - OFF indicator open, driving circuit trouble
Present
I have looked these codes up in the service manual (downloaded from T4R) and read them. Might as well be a foreign language!:frusty:
My first thought is either the "floor wire" or "front seat wire No. 1" since this occurred during a shopping trip and it was OK going in and not OK when we left. Any idea where either of these are? There is a bunch of wires connected to the seat...
Any help would be very grateful.
Basically the seat pad circuit is malfunctioning. There could be an issue with the seat pad itself, the wiring, the connectors, ect.
I would do as Oljedi suggested and unplug/reconnect the yellow connectors under the seat first and see if it goes away. SRS DTCs are much like ABS in that they are single trip, when the issue is fixed; 9/10 they turn off by themselves and store a history DTC.
If the issue persists, then you will most likely need a new occupant detection pad that is in the lower seat cushion; if you buy the part most any upholstery shop can do it for you, or a dealership.
Excuse my ignorance, but I do not see this 'occupant detection pad' in any of the diagrams. I do see 4 sensors (one on each corner) that connect to the occupant classification ECU. Please help me understand.
I unplugged/plugged in the the connectors that i could reach tonight and no change. I will look for the yellow ones you described in the daylight. Also it is not a 'power seat' so only recline and back/forth.
thx :)
Little confused on the parts that can be ordered.
I have found this ($299)
COMPUTER, OCCUPANT DETECTION for 2006 TOYOTA 4Runner. #8995235011
COMPUTER, OCCUPANT DETECTION.
COMPUTER, OCCUPANT D FRONT SEAT-BASE FABRIC,SEPA.TYPE,4WAY,W/O(LUMBAR.); KOREA; KOREA SPEC; MEXICO SPEC&SRS AIR BAG-DRIVER; SRS AIR BAG-DRIVER & PASSENGER; W(FABRIC SEAT); W(MANUAL SEAT)
Is it correct to assume that this is the 'pad' which is really the entire seat base with the 4 sensors and ECU???
Otherwise I found this what appears to be just the ECU
Occupant Detection Sensor
DORMAN Part # 601004
2006 TOYOTA 4RUNNER Occupant Detection Sensor
This stuff is freaking expensive :dammit:
Thanks for putting up with my rambeling :blah:
Whoops, you're right. Sorry thinking of something completely different...
So it is basically an issue with either the SRS Center Airbag Snsor Assembly, the Occupant Detection Module, and/or the wiring in between. At this point we would need to verify that the wiring is intact and then if that checks out good determine which module may have failed. The B1152 indicates a failure in the Passenger ON/OFF Airbag warning lamp circuit; which could point to the SRS Center Airbag Sensor Assembly.
Here is a section from the FSM detailing a DTC B1150 (I realize it is from an '04; but everything should be the same.)
View attachment CI__B1150_23_B__.pdf
I HIGHLY urge you to disconnect the battery when working/testing the SRS system unless the FSM states otherwise for testing purposes. Also NEVER under any circumstances have the Center Airbag Sensor Assembly plugged in and unbolted; tilting the sensor assembly WILL deploy the airbags if the battery is hooked up and the module is not bolted down properly (also never use an impact tool when installing, always hand tools.)
No worries...I'm learning more that I have ever wanted to know about SRS systems....
What I really need is the software that can actually connect to the system and read each individual sensor...wishful thinking i know...
Actually if you search threads for "Chinese TIS Techstream" and such you can probably do just that...
SOLVED!!!!
I got the TIS Techstream and mini-VIM cable from AMAZON for $25. Plugged it into the 4Runner and went to the SRS system. It gave me a different code than before (didn't write it down :( ) but it said that it needed a "Zero Point Calibration" so following the prompts I did what it said. Then it said to do a sensitivity test. Done.
ALL WORKS NORMAL :) SRS light off and passenger OFF/ON and seat-belt indicator all back to normal :)
Thank you BlackWorksInc and everyone else that chimed in :) :snacker::snacker::snacker::snacker::snacker:
SOLVED!!!!
What cable did you get? Can you provide a link to it? From what I've read, there is the genuine Mongoose cable running TIS Techstream Lite, an approved aftermarket one (it's over $600). Whereas, all the cheap ones are Chinese knock-offs. Which is fine (I don't care). I'm just worried that not all the Chinese knock-offs will be able to read SRS.
So if you could point me in the right direction to the one you got, that would be great! :)
