P0113 - MAF high voltage?
4OYOTER
Out of nowhere yesterday I threw this code. 2008 4.7 with 127K. No driveability issues. I cleaned the MAF at approx 113K. I cleaned the MAF again and checked the harness. Reset the CEL and it hasn’t returned. Should I look into this any further? The only wiring modifications I have are the slyfox SAIP bypass kit that does tap into the MAF harness.
Same just happened to me except except mine won't clear. I had maf unplugged last night so I'm guessing I dinked a connection.
Slyfox AIP bypass module installed a long a time ago.
And fixed. The solderless connector strikes again! Noted to go back and actually solder this soon.
I've got this same error code, P0113, with the Hewitt kit installed.
Where should I look on the harness/loom for bad connectors? I can't tell from that picture.
'05 V8 4Runner.
RennSport2UZ
