With 2" Lift, Do i need to change brake line hoses?
Jacobzky
i just installed 5100 with clip set on the third line using the stock coil, it gained about ~1.75" lift. and new 275/70R17 tires. Now when going offroading, should i be worried about my brake line being stretched out, is this even a concern at 1.75" lift?
Its not a concern with any amount of front lift. You basically have the same travel as stock you just lifted your truck so to speak.
If you have super long rear shocks only then does it become an issue for the rear lines.
Thank you for the info.
