Blacking out FJ Wheels (Lots of Pics)
BlairB
MORE PICS OF FINAL PRODUCT ADDED TO PAGE 4! Instructions below
DSC09290.jpg~original
DSC09287.jpg~original
Well I decided that I wanted to go a different direction with my wheels so I started a little project. I found a set of FJ wheels locally, which I actually got for free, since they had some rock rash from off roading. Before doing the entire project I decided to mount and balance one wheel and tire, just to test fit b/c I was curious how much rubbing I would get with spidertrax and the increased offset. After test fitting I decided I also wanted to try the entire wheel painting process one time through, which this thread documents.
This thread help inspire and direct me with what to do about the wheels.
Step 1- Get some FJ wheels! (There are only 4 in the pic, but I have 5, one of which is already on the tire)
DSC09261.jpg~original
Step 2- Clean the wheels. For this I used soap and water, then wheel degreaser, then soap and water again to get any residue off. Also, on some of the wheels I had to take some very deep scratches out, which required various grit sandpapers. You can see some of the spokes in the previous picture have been sanded already.
Step 3- Rough up the entire finish of the wheel, so that the paint will stick better. For this I used 320 grit sandpaper.
Step 4- Clean the wheel again to get all the dust from sanding off.
Step 5- Mask of tire. Also, if you paint it off the tire, I would mask off the bead. Note: you can also see how the wheel looks when sanded some.
DSC09264.jpg~original
DSC09262.jpg~original
Step 6- Spray 2 coats of primer. I used Dupli-Color Black Primer. It will probably take around 3 cans. I waited 10-15 minutes between coats. I also sanded and primered the center cap. For the center caps you can pop the little Toyota logo off, I think I am going to keep mine silver, and think the contrast will look good.
DSC09265.jpg~original
DSC09266.jpg~original
Step 7- Spray your final coats of paint. I used Dupli-Color Satin Black Wheel Paint (HWP-104) and let the primer dry for around an hour prior to painting. I put on 4 coats, the first 2 relatively light, the second 2 more thick. I was sort of disappointed with how this paint sprayed when compared to the primer. It was really hard to get a nice even coat on. Also, the nozzle on the wheel paint sucks in comparison to the one on the primer. It will take 4 cans to do this, for me it may be more since the wind picked up and not as much paint ended up on the wheel as I had wanted. Here is a pic after I started taking some of the masking tape off.
EDIT: I ended up using Rustoleum Satin Black Paint, since the Dupli Color was impossible to get a nice even coat with
DSC09269.jpg~original
And here is the wheel placed in front of my truck, so you can get some idea about how different a look these will give my truck when compared to the stock sport wheels.
DSC09268.jpg~original
I would say currently the look of the wheel is a 7/10. They look good, but due to the troubles getting an even coat on I think they could look better. I might try another coat in better light with no wind, or using very very very fine bronze-wool.
Hope this helps some other people who are thinking of doing the same thing! Good alternative to powdercoating.
Let me know what you think!
Nice job! I like the satin look a lot.
Instead of wool, find some GRAY 3M scuff pads. They are similar to scotch brite pads but with a finer abrasive on them to prep for topcoating. It will save you a lot of time.
i like it! to me, the black fj wheels will look better, cant wait to see it with all of them done.
wis99ski said:
what is that red car in the first bay?
Looks like a ferrari ..
Correct. It's his dad's.
Blair, when do you plan on doing the other 4 wheels?
Text me if you're free tonight when you get off work.
Damn, good eye!
BlairB, the paint rims look good! Did i tell you how much i really like your tires?! :)
Besides this being cheaper, did you ever consider powdercoating?
Thai said:
Damn, good eye!
In Blair's original post:
Ahh, did not read all the way to the bottom...just looked at the pics! :biggrin2:
HB 4X4 said:
Looks good man, can't wait to see the finished product of all 4.
etom said:
Trdsupranick said:
I think black wheels with black trucks looks great.....nice job man!
Thanks guys, I am definitely excited to see the final product. I was not totally sure if black would look great on my truck initially, but now I am really excited.
dum8ss1236 said:
what do you do with the paint on the tire? Let it wear off? looks good btw
eskimochaos said:
Yea it seems you were "careless" and didnt cover the tire and now its black...does it just rub off?
The overspray on the tire is actually very very minor and since the tire is dirty and rubber it does not stick whatsoever. When I was done I took a towel and wiped all of it right off. It looks worse than it is since when I was painting the wind picked up and cause more overspray then normal.
Great! Good to know as I will be painting my SE rims shortly. Is there any chance of getting rub marks/scratches if I were to get new tires after I painted in the wheels? Obviously there is a change some jackass might scratch them but if done properly does the tire mounting machine even come in contact with the outer part of the rim?
Haha yeah, that is my dads toy, not quite a lifted 4runner...
And I plan on hopefully doing the rest of the wheels this coming weekend and will hopefully get them mounted towards the end of next week
Thai said:
Damn, good eye!
Yeah I really did think of powdercoating, but there are 3 reasons that I decided to do it myself rather than getting them PCed.
1) Cheaper
2) I was not sure if black wheels would look good on my truck, so why waste that money on powdercoating.
3) The biggest advantage many point out in powdercoating is the strength of the paint, but I figure my wheels will get damaged, and the sort of scratches I will get (from off roading) are just as likely to occur on powdercoated wheels than my rattle canned wheels. Plus mine would be far easier to fix :)
I was actually worried about this, but at least by me, the part of the mounting machine that touches the wheel seems to be a plastic piece so I think I should be good. I will actually be painting the other 4 wheels off the tire, so I will let you know if I run into any problems. I just need to make sure I give the wheels the full 7 days to dry, otherwise the paint will be too soft and much more likely to be damaged.
....and actually when I look at the pics of the tires, those were taken just after I took the overspray off with a damp towel. So that is just a clean/wet tire sidewall just standing out from the dirt in the tread/lugs. Not paint :D
