Oil Change 5th Gen: How To- LOTS of PICS!
I performed my first oil change using the ValvoMax that I installed a few months ago. I’ve checked on it occasionally to make sure it did not leak. Not a drop.
I connected a longer hose to the mating drain tool fitting and drained the oil right into two one-gallon jugs. At stock height and no ramps there’s not much room underneath so I had to position them just right. Due to the small diameter of the ValvoMax the oil drains slowly. After one gallon jug was almost full I pinched the tube and moved it to the second jug for the remaining 2+ quarts.
Using the MotivX oil filter drain tool was a snap. Just screw the fitting into the filter drain and pipe the oil into the gallon jug. No mess and no plastic drain thingy to deal with. However, removing the actual filter housing is a little messy with some drippage, so have a drain bucket and paper towels handy.
After removing and cleaning up the plastic oil filter housing I removed the longer perforated tube and installed it into a new metal filter housing. New filter, new gaskets, and everything fits well.
After refilling the oil I left the skid plate off for a day and made sure there were no leaks around the new filter housing. Looking good!
Did you get that MotivX oil filter drain tool at an auto parts store or on-line. Amazon doesn't have just the drain tool, you have to get the wrench with it too. There is another Chinese brand on Amazon that does the same thing. JDT Drain Tool
Just finished my first 4Runner oil change this morning. A bit more fuss than a spin on filter but overall not too bad. I did use the Motivx filter housing drain tool. And replaced the plastic filter housing with the metal housing. :whoo:
The only issue I have is the oil is so clear (Amsoil 0W20) I can't get a clear reading on the dip stick. Literally cannot tell how much oil is in there. :shrug:
FWIW I used the JDT tool. Works fine and seems to be of good quality.
Can you post some photos of the Napa part? Curious to see how it compares to the OEM housing.
You can just tell the Toyota one is better quality by the pics. I think the big issue with this one is the threads may be too thin. Who knows, it leaked and was a piss off.
Yeah. I put in 6.0 quarts then checked the dipstick about 10 times to calibrate my technique for reading the level. Then added a few ounces until it reached about 6.5 quarts. One side of the dipstick seems to always get smeared with oil no matter what you do.
Give it a day or two and you will. As long as you put at least 6 qts in there it's not running dry. And as said above, make sure you look at both sides of the dipstick. One side does tend to get smeared with oil and look wrong sometimes.
Take some sandpaper and rough up the end of the dipstick. You can read it easily then.
OK oil change people. This was my gift from the dealer this weekend when they gave me a free oil change (1 year at 7k miles) (in addition to getting oil all over my RCI skids):
Note the tab is past the line on the metal casing.
Is that the kind of thing that's going to make it really hard to get off in a year when its time for the next one, or not too bad?
Just did my 1st oil change last night, I went with Amsoil 0w20 also. I was surprised how much tiny metal shavings were in the bottom of the housing. Only has 2300 miles on it but still interesting to see. I lubed up the new gasket Very well but as I tightened it up it seemed to get very dry; anyone else notice this?
Just did my first change last night and that’s Exactly where my metal tab ended up. And from factory it was in about the same location.
My tab was lined up exactly at the indicator from the factory. I don't torque my housing, I simply align the tab to the indicator on the last turn and I'm done. The dealership is the last place I'd have my oil changed....just too many horror stories.
Hmmmm... That’s interesting, I went about a quarter inch past the tab on the housing and I had a slight leak. I had to tighten it up about 3/4 to 1’’ inch to get it to stop seeping oil.
Where is everyone’ tab at?
In 2010 mine looked like this from the factory...and that's as far as it goes when I re-install it to correct torque.
You can try backing it off, it's not going to cause a leak with that type of o-ring seal.
31239d1280089849-recommendation-oil-changes-img_2203_8_1_1-jpg
Thanks. I think for now I will let sleeping dogs lie. It's not leaking and there is fresh oil in the engine. I just read another thread about people who had the cover fail when trying to remove one over-tightened, and that's not fun I need right now.
At Christmas when work is a bit slower and I have a few days off, I'll probably re-do the oil change to make sure it's done right and put on a fumoto valve while I'm at it. And if I have any problems with cracked cap etc., that gives me time to sort it out when I don't need to drive.
Plus, since I drive less than 10k a year, I will have a new annual Christmas tradition. Oil change and egg nog.
Torque mine to 18lbs every time and never had an issue. My tab goes at least an inch past the pointer, always has. I torque the small cap at the bottom once the oring is aligned correctly to 10lbs. Never had any issues with leaks. Also, I use a cheap (Pennzoil I think) oil filter wrench without issue. It cost me $9.
AndiGarage
