Build assistance - Feedback on suspension choices for my usage.
I got the suspension ordered. I ended up going with the Bilstein 5100, Eibach 1.6" front springs and the Sway-A-Way 1.5" Eibach rear springs. I will set the Bilstein front at .85". I grabbed a top plate spacer just in case I get the lean. Here's to hoping the alignment works out and I don't have to go back and re-do the work and install Camburg/Moog UCA's.
Jason - Once I have an ETA on things I will reach out to you. Very appreciated.
Now, which tires to get but that's a new thread! ;)
Thanks everyone!
Excellent, I think you will be happy with your choice. If you happen to need UCA's to get the caster within spec, it is not a big deal to do after the fact. You will just need another alignment, obviously.
Let me know and we can plan when to hook up.
Why hasn't anyone suggested a Hi Lift? I think it's more versatile for solo use than a winch or a come along.
u need a suspension you can tune and adjust....
i cant say enough good praise about Fox 2.5 w/DSC front & rear!
tune your own ride in w/low & high speed adjusters...
suspension nirvana!!!!
I have Fox 2.5 DSC in the rear and they are very nice, but I think it's complete overkill for the OP's use.
They are. Problem is if you give a Hi Lift to 99% of the people and tell them to use it to get their truck unstuck their truck will still be stuck three days from now.
If you treat the Hi Lift with the respect it deserves and learn how to use it properly it's one of the best self-recovery tools out there. A come along and winch can be just as dangerous if not used properly. You need to learn how to use any recovery tool properly in a controlled situation - not at 3am miles from civilization and out of cell phone range ;)
My vote is still for a Hi Lift with Lift Mate and winch kit, maybe one of those fancy base plates too. A winch won't help if you're high centred, but you can jack and stack rocks with the Hi Lift.
I just got a hi lift, base plate and lift mate given to me by my brother whom just got out of Jeepin. Its only been used a few times. Now I just need to learn how to use it. We've got some teaching time set aside. Any recommendations on a winch kit for strapping and rope to use with the high lift?
First, go over the jack to make sure everything is in proper working order. Here's a video on maintaining the jack, which you'll probably want to do right off the bat.
https://youtu.be/NIeASvjxDtU
If you need to replace the climbing pins you can get a Fix-It kit from Hi Lift. Here's a tutorial my friend wrote on replacing them:
Fixing the Farm Jack ? Untitled Offroad
When you use the Hi Lift as a winch, make sure in this case that you're using a tow strap or winch extension strap - something with no stretch - rather than a recovery strap.
Thanks everyone!
Keep me in the loop with this. I'm helping [MENTION=78318]RiDE[/MENTION] at some point with the wiring for his lights and some body part swapping. We could have a full on wrenching party somewhere!
Keith-you know I know a guy who's selling some pretty sweet Nitto TrailGrapplers and some really good looking wheels...:eyebrows:
Haha. I saw them in the classifieds. I am happy with the strength/bead retention of stock Toyota wheels. Plus i am a fan of the clean, stealth, OEM look. You guys should reply to my tire thread. ;)
