Another Bilstein 5100 question
Checked with a couple of local shops here in DFW and found that Front 5100s can be had within 3-days but no word on rears. It could be 3-weeks or 3-months.
So I am thinking of getting hold of Fronts, get it installed with .85 setting and keep the rear stock. Stock shock, stock coil, just until I get hold of rear 5100s and then make the change for rears.
I know couple of folks did 5100s all around set at .85 to level it out. But can this be done with Front 5100s at .85 and rear completely stock?
This would not be a problem at all.
There would be no issue with that. That being said, why don't you just grab a set off eBay or Amazon like these?: Bilstein 33-187174 Set of 2 Rear Shocks for 03-15 GX470/4Runner/FJ Cruiser | eBay
Received a set of 5100s today
I received a set of 5100s today and I have a set of 2inch Icon rear coils that were gifted to me.
With the 5100s at the 2 highest settings can they be paired with the rear 2inch icon coils and look/ride ok? Has anyone done a set up like this? This will be my first lift.
Tried searching the threads but not having luck.
Moving to new '22 4R and will be putting on 5100's on this one as well, but was curious if anyone has used the OME springs with them?
Looking at OME 2884 2.5" coils on front, OME 2895 2" springs in back.
Thanks in advance if anyone has any feedback on this setup.
In short, it's fine.
I currently have 5100s paired with Dobinsons coils that are roughly the same height, and they work great.
The thing to remember is that the shocks and the coils are essentially independent. With stock, or at least stock height coils, you can use the adjustable 5100s to get some leveling height IN THE FRONT ONLY.
However, if you're getting lift up front from larger coils, you will want the front shocks set on the lowest perch. The height comes from the springs at that point, not the shocks.
I'm aware of the 5100's + lift springs config, thanks.
Was curious about ride/stance with this combo (or something very similar such as yours).
Thanks
Thanks
Apologies, I must have misread the intent of your question.
I like the current stance, it's pretty much level at the fenders. Though that's changing a bit as I add the weight of the front bumper and skid.
The ride is pretty good, road driving is comfortable. I'm just finding I have to take larger speed bumps a little slower than I used to.
Cheers!
Tire fitment question:
Wheels are 8.5 -10 SCS
About to order the Bilsteins and was wondering…
If I adjust the front setting to 1.75 will I be able to fit 275 wildpeak AT3’s?
I’m sure I’ll have to do liner mod. But I really don’t want to give up the mud guards.
Non-KDSS btw..
Thanks in advance everyone
Non-KDSS btw..
On my current 4R I have the Bilsteins at 1.75 in front using factory springs and I have the 275 AT3s, no rubbing or issues up front. But I am using factory TRD wheels with no spacers/offset.
Thanks for some positive feedback! It gives me hope…
I’m hopeful I get the same results with the SCS wheels
I read this thread almost all the way through..
Here is where I landed and my thoughts..
21 4runner Venture
installed 5100's on all 4 corners set to lowest settings
OME 885 springs front and rear
285 Toyo AT3
Alignment came in good, but caster is 1 degree to the rear.
I had a small amount of rubbing on the liner and front mud flaps. Modded the liner and mud flaps a bit and have had no issues since.
Truck doesnt sit quite level, still a tiny bit of rake. The ride is pretty close to factory, nose dive isn't as bad, but still noticeable.
Getting 4 bilsteins and cornfed 3/4” installed Thursday.
Mechanic doing alignment as well.
Should I wait for a few days to get the alignment or just have him do it time of install?
Non-KDSS btw..
For reference I ended up going with 265 KO2 and I only rub in full lock reverse on driver side mud flap. Need to break out the heat gun eventually…
Loving the way the 4Runner looks now.
Doesn’t look like a Prius anymore
I just completed the exact setup on my 2018 ORP. Very pleased with the results. These should have been the factory shock or at least the Bilstein 4600 like the Tacoma use to be in my opinion. Bilsteins and Michelin Defender M/S combination makes all the difference on this truck for a road setup.
Finally got to doing my 5100 upgrade.
Used the 1.75" setting up front and a 0.75" Cornfed spacer in the rear.
Switched to Pro wheels and new tires. Tires are LT load range C General Grabber ATX 265/70/17 (would not have been my first choice but they were essentially new and came with the wheels when I bought them). Aligned, swapped TPMS, and balanced tires.
Quite happy with how it came out!
This looks perfect! Looking to do the same to my wife's 23 ORP soon. Thanks for posting pictures.
