b407driver
Believe me, I’ve searched, found, and read every thread possible to try and glean the info I need! There’s so much confounding information about towing on the forums, from people towing max 5000 lbs at 10k just fine, to people who think the 5th Gen sucks at sea level with 3000 lbs.
I think I now need specific towing experiences/suggestions from 5th Gen owners who live in Colorado and routinely tow in the mountains. I know I didn’t buy the 4Runner as a tow vehicle (who would?), but it’s what I have, and I knew I’d have to make-do with the limited towing I’ll do.
Here’s my dilemma:
My wife and I are trying to settle on an Ultralight Travel Trailer (KZ SC 151RB, Lance 1475, R-Pod RP-180, etc.), with some pretty specific limitations:
The more we look at trailers and the more I read people’s experiences, the more I convince myself that I need to keep the weight as low as possible. Right now, the trailers that barely satisfy our minimum requirements have dry weights around 2500-2700 lbs, giving actual weights (on the lot, with options) of 2700-2950# lbs., with GVWR in the 3500-3800# range. I’ve estimated that our likely loading will result in total trailer weights around 3400-3700#. The truck is likely to be loaded to about 5850#, giving a combined of 9500#+ (which leaves an available vehicle payload of ~500 lbs. remaining). The heaviest of the five trailers currently in the running is estimated to be 3675# loaded, almost exactly 75% of the 4Runner’s 4900# tow rating. Vehicle is a '16 TRD Trail w/KDSS, stock size Cooper AT3 Load C.
It will be used maybe 1-2x/month mostly in CO, WY, UT, and NM, with occasional longer trips, always hauling two mountain bikes on a hitch-mount. I have no interest being limited to driving 30mph up Floyd Hill, I'd at least like to be in the ballpark.
Since you can’t load up a trailer and go test drive it, I guess at this point I need to rely on the expertise of people who live in similar environments that tow with their 5th Gen 4Runner. I’m trying to figure out if pulling ~3500 lbs. will be a mistake, living here in CO. I’d be willing to install airbags, a transmission cooler and W/D hitch if necessary (as well as brakes/controller), but I’m a towing noob, and don’t really know what makes the most sense. Heck, I still cannot decipher from the forums whether a W/D hitch should even be used, or is needed with out trucks!
In a perfect world I’d love to hear information relating to how much weight can be *reasonably* pulled in the Front Range environment, where virtually anywhere I want to go entails crossing at least one mountain pass of 10,000 feet, if not several, as well as any of the above-mentioned options you’d consider useless or priceless.
Lastly, thanks in advance for any help you might be able to provide. I have a chance to try and get this right the first time, and since there’s no turning back on vehicle choice now, I need to get the trailer that will work for the truck and the environment I’m in.
Cheers!
PS: I included a screenshot of my homework.
Here’s my dilemma:
- ‘we’ (cough!) want a dry bathroom (i.e. no showering/shitting at the same time);
- we’d like an actual queen bed (i.e. no Murphy or build-a-bed);
- we’d prefer it to sleep 3-4, but 2 may have to work (kids are nearly out to college, anyway); and
- it must be hard-sided, obviously (and no A-frames).
Cheers!
