i removed it today, wasnt bad after i figured it out, some tight spots but can be done with fingers after you remove the bottom shroud.
Bottom Shroud has 5 10mm bolts and a push plug that you need a butter knife or pry tool to remove.
<a href="https://ibb.co/VMSWG8s"><img src="https://i.ibb.co/XFsZPTq/IMG-3753-1.jpg" alt="IMG-3753-1" border="0"></a>
the bumper valance for front has a bunch of white clips holding it on. i used my hand to remove them all. might need a small tool that pushes down the fastener so it pops out. i was lucky with it. you can see all the clips there, i put them in place, some are hard to find with your hand.
<a href="https://ibb.co/SBGNqHF"><img src="https://i.ibb.co/WfjnS7m/IMG-3754-1.jpg" alt="IMG-3754-1" border="0"></a>
there is truck with no valance on front. this will make painting it easier and a better job can be done this way.
<a href="https://ibb.co/ck0jB6N"><img src="https://i.ibb.co/rFYVjxZ/IMG-3752-1.jpg" alt="IMG-3752-1" border="0"></a>
i did a micro crackle texture, i used Krylon colormaster matte black first, then did lots of Rustoleum peel coat splatter coats till even, then Rustoleum fexidip splatter coats til even, chemical reaction creates a texture like leather. use techniques like this alot when i do the car builds, sometimes it has to be wiped off and redone, got lucky and pattern came out nice and even, now it has to sit all night then be washed and installed in the morning.
<a href="https://ibb.co/JBSwnf0"><img src="https://i.ibb.co/p0kB2tG/IMG-3758-1.jpg" alt="IMG-3758-1" border="0"></a>
