How much air can your tires hold?
Ok, I ran the test:
1. I drove the tank on my 2016 TRDP to empty; (I know I know)
2. I poured in 1 gallon of fuel;
3. I drove 1.3 miles to the nearest fuel station; &
4. I filled the tank until fuel poured out the top & the pump read 24.003 gallons
Conclusion: A 2016 T4R holds almost precisely 25 gallons.
Have a nice day...
Well, well, well.
I had no idea my actions would upset so many of you. I find it curious how many people are so concerned with what I do with MY vehicle that I paid for with MY money.
I apologize to all you nice people. I am sorry I troubled you by posting this. I won't make the same mistake again.:hunter:
Draining the tank to empty is bad. Topping it off is bad. Negative replies to your post are a warning to others who might not realize that they could damage their vehicle by following in your steps.Well, well, well.
Ok, I ran the test:
Have a nice day...
That only helps if the water is coming straight out of the hot water heater.
Unfortunately I overflowed the gas in my 4Runner last August, when I was at a rundown old gas station in Nevada. The shutoff on the nozzle was broken, and took me by surprise.
If you're referring to the "Cruising Range" indicator, they left a lot of cushion on it. I believe when that hits 0, you still should have about 3 gallons of gas left.
Based on my fill up experiences (to the first click on a pump only), the light comes on around 4 gallons left (19 fill up) and the read out hits 0 with around 3 gallons left (20 fill up).
I assume this is because there's a bunch of people out there who refuses to fill up until the last second and will drive it until they're out of gas if it actually ran out at 0.
Mine shows 1 mile at 3 gallons. I just reset the mileage button and make sure I don't go over about 40 miles additional.
The original post in this thread got some of us to kidding around. This morning at tacomaworld.com - someone posted the following.
Looks like someone actually did it at least once:
I'm done with this car! - MustangForums.com
