Longboard "Mount" "Carriers" for interior headliner
FiReBReTHa
Hokay,
so having 2 longboards, 2 skateboards and then my "Truck" gear, there's no room for my costco runs ;)
I started pondering about a ceiling rack for carrying the boards securely. I would remove the "ohshitgrabhandles" and use the rear coat hanger brackets for the mounting points. I didn't want to use a soft net because I didnt feel it was secure enough and it would have the grit side against the headliner.
https://www.toyota-4runner.org/5th-gen-t4rs/205513-interior-roof-rack.html
Anyone seen anything or have any thoughts on mounting solutions?
TIA!
Interestingly enough, there is a post talking about this system just a few below yours. Might be worth checking out:
Rago Modular Storage Panel Shelf
5th Gen Toyota 4Runner Modular Storage Panel System – Rago Fabrication
Alternatively, maybe you could get a set of these and hang the boards from them:
I'm not saying the solutions you are looking at wouldn't work... but these might be a little more "stout." You could probably fab up something pretty easy to keep them up and out of the way, but these would have "other uses" for when you need to get additional gear that you might not get out of the options you are considering.
This is the cheapest and easiest way to do it. Still plenty sturdy.
For the rear strap, I got some D-rings and screwed them into the rear most coat hooks. Then looped a sturdy tie down from d-ring to d-ring.
For the front strap, I just looped a tie down from the rear seats grab handle to grab handle.
My boards are shortboards.......the longest being 5'9". Not sure if a longboard would fit there and still give you enough head room, but it's worth a try.
That’s what reflective board bags and roof racks are for. Do you really want melted wax all over your headliner? Why are you taking your boards to Costco anyway?
That cross piece is new! didn't come across that. Definitely going to learn more about it.
Woops,
"Longboard" = Long skateboard. Always have em on hand with me if we come across some cool trails.
Just about anything that will strap it down between the trucks will do.
If money was no option I would ge the rango panel shelf. Get two industrial velcro straps or buckles, attach it to the bottom of that, with a rubber pad double sided to the mounting area for vibration/scratching. But, I have no business getting on a skateboard anymore, so w.e. :shrug:
So I started taking everyones bits and pieces and putting them together.
I didnt include the foam or tie downs yet since this is still the rough concept.
I saw the tie downs behind the seat and figured I can remove the buckles and use the bolt mounting there in addition to the one where the retractable cover goes for a four point mounting structure that can handle the weight of all the boards.
It would be modular enough that I can tweak it for different width boards and make it taller etc for the final variant etc since 80/20 is easy enough to work with.
Anything ever come of this?
