Are LED fog lights standard for 2021?
arouth
Hi,
I priced out a 2021 4Runner and saw there is an option to add on LED Fog Lights for $349 under accessories. However, when you look through the specs it says LED fog lights are standard like the LED Headlights.
This was the 2021 4Runner SR5 Premium. Any info on this since I might be buying one soon and I’m guessing the dealership isn’t going to know lol. I‘be attached a couple of pictures for reference.
Thanks
Are they the 2-in-1? They had that on the ‘18 as an option. LED fog/driving light depending on what setting the headlight was on. A lot of stock fogs will cut off on certain headlight settings.
"High performance" LED fogs?
Related question; I've just started contacting dealers re a '21 TRDORP and one of the build sheets includes "High-Performance LED Fog Lights". An image of this part of the build sheet is attached.
Guessing it's a port add-on (the vehicle is not yet at the dealer) and I don't see this option on the Toyota build page. Has anyone seen these or know what it is relative to the standard LED fogs on the ORP?
Thanks!
So I have a 21 ORP coming in a couple weeks or so. The only option it has is upgraded led fogs for $169. It seems that this is an option that’s carried over from last years model. It’s a port installed option. Why it has this upgrade when all the 21s come with led fogs standard I don’t know, but it’s as close to no added options as I could find in my region. Guess I’ll find out what they are like when it shows up at my dealer.
If your new 4Runner doesn't come with them, you can easily add them. The factory LED fogs are direct fit to the halogen fogs. Part numbers are 81210-48051 (right) and 81220-48051 (left). I exchanged them on my '18 SR5 Premium. One word of caution: the right side fog is hard to get to for there is a bracket hiding it that is hard to remove.
GENUINE TOYOTA LAND CRUISER LEXUS CT200H ES350 IS350 RIGHT FOG LAMP 81210-48051 | eBay
In my trd off road,
it has
LED low beam,
LED fog lights,
Halogen daytime running light,
Halogen high beam.
