2020 Limited nightshade help
laqualo
Hello again. Just picked up a limited nightshade. Love it except for the stock tires. I would like to move to a slightly more aggressive wider tire I live in calgary Alberta so want it to handle all seasons wondering if I should do a levelling kit or small lift to make room for the larger tires. I’m not looking for anything over the top just subtle that makes it look a touch more off-road Not sure if the level or lift is even needed so please chime in. Also if you can recommend a slightly larger / wider tire size it would be appreciated.
Here’s a pic
If you only want wider tires you can go 265/70/17. Here is my Nightshade with winter tires on 17x8 wheels.
Thank you. I was looking for a tire for the stock 20s.
Then you will quickly come to the conclusion that your options are limited by the stock wheel width. 275/55/20 is possible but it is out of most tire manufacturer recommandations.
A picture from jasehock in another thread.
img_8589-jpg.25622
Then you will quickly come to the conclusion that your options are limited by the stock wheel width. 275/55/20 is possible but it is out of most tire manufacturers.
img_8589-jpg.25622
This tire looks great.
Thanks for all the responses
Looking like I’m going with the 275/55/20 toyo open country AT. From everything I’m reading looks to be a lighter tire so won’t effect performance to bad. Does anyone know if these tires are still ok for winter ?
limited 20's replacement
rookie question.....
Can you mount trail rims and tires on the LTD.....I thought I saw a guy rolling past me in a LTD with Trail Rims / Tires today
I was going to put this tire on my Nightshade as well, but was told by the dealer that they will rub.
Yes spoke to my dealer as well. They said they do this swap a lot and just need to trim a tiny amount in front wheel well to stop minor rubbing from full lock in reverse.
As I see you are also in Calgary just wondering what dealer you went to?
