I deposited for a 2022 limted not realizing that 20" wheels are not the best for off road. Is there any problem putting 17" wheels on the limited for more appropriate tires for off road?
[MENTION=95539]SirWilliamGoes[/MENTION]
What are those tires you have on?
Toyo Open Country MT
The existing tires are the the factory installed 20" P245/60R20. No longer an issue though as I cancelled the order for the Limited and bought a TRD Off-Road Premium expecting delivery mid-April.[MENTION=95539]SirWilliamGoes[/MENTION]
Let the best contact patch determine your tire pressure (rather than internet experts)
Choosing Tire Pressure using Static Contact Patch Measurements | Kelvin Tse
You can easily do this with chalk
Tire Pressure Chalk Test - YouTube
Sent from my Pixel 4 XL using Tapatalk
TOYO Open Country AT3's, LOVE them in this size. Handle better and feels lighter in the steering, road noise is reduced from my WildPeaks, and SOOOO much better in snow and ice than the WildPeaks. Still a very small about of rubbing on the passer side in reverse, need a BMC. Yeah, wider looks cooler I guess, but I am sold on cookie cutters.
PROS:
1. Drivability
2. My gas milage actually went up a little
3. Able to deflate to 18-20 psi with no concerns
4. Great in winter
5. With my SCS wheels, pretty close to stock weight combined
6. Tall for clearance
7. Quiet
8. Wearing great
9. Balanced no issue, no road force balance needed
10. Fit in the spare location
CONS:
1. A regear might be in my future, highway mostly. Just a little too much gear hunting here in Colorado
This is great to hear about the Toyo AT3. I'm considering these over the Wildpeaks as my next tire in 255/80. Is the rubbing a result of the wheels?
Finally got the new tires on, and went with 255/80 Nitto Ridge Grapplers.
They measure in at about 33.25 inches in diameter and other than having to push the front fender liner forward by about 1/2 in, they fit great, and no rubbing at all. At least with the little bit I played around. Later on I'll get to some proper trails and disconnect the sway bars, but I think it is going to be in the clear..
THey ride pretty smooth and are actually much quieter than the blizzaks I run in the winter... I'm quite pleased...
