Do I really need to replace rotors?
Fareastplaza
My 2010 4Runner has 200,000 kilometers on it, and it's still running with the original rotors. Lately, I’ve noticed some vibration when braking at speeds over 90 km/h, so I decided to take a closer look. After removing the rotors, they appear to be in decent shape aside from some rust on the inner layer. The thickness is still good with only minor wear, enough that they could probably last a bit longer. However, I’ve already purchased new rotors, which I can’t return.
My question is, have I been driving too cautiously over the last 14 years? When do most people typically replace their rotors? I live in Alberta, where winter roads are tough with salt and ice. I'd love to hear from others about their experiences with rotor wear in similar conditions.
You need to have them tested for wear thickness and runout to fully diagnose. TBH at 120K they would be close to being done, so replacing them is probably the way to go. That said, do not count on the new ones curing the steering wheel pulse at 60 mph.
I’ve got the same decision to make. 140k miles on my original pads and discs and replacement parts on the shelf. My discs exceed minimum thickness by almost 3mm and runout is well within spec. My concern with replacing the discs is running into installation issues beyond my capabilities, like stuck or broken bolts.
…and I agree with Mr. slam regarding vibration.
Only minor wear, to me, screams that you should check and make sure all the brakes are working.
Had a 97 Saturn, and I replaced pretty much everything on the back except cylinders and lines when I got it, since the bearings were shot, and I found a screaming deal on the drums, pads, springs, etc. After a couple months of wondering why my braking was kinda weak, I pulled the drums off again, and everything still looked brand new. Turned out the cylinders, lines and banjo bolts were packed solid with rust, and I'd been on front brakes only the whole time.
I have about 270,000km on my 2012 and here's the replacement schedule I'ev had:
I did my fronts at 168,000km and about 260,000km
and rears at 65,000km, 134,000km, 195,000km and 260,000km
rears seem to go faster for some reason. good life you've gotten out of your rotors, but brakes and tires are places I don't cut costs. replace them since you have them and you will probably be fine for a while
You're definitely due to replace the rotors. However, your vibration could be because of a number of different issues, i.e. ball joints, control arm bushings or tie rods.
I typically DIY brakes and service on my audi and 4runner. The audi has about 95k miles on it and just within the past month started some pulsating at 60mph plus while braking. I changed the front rotors & pads yesterday and it wasnt a bad job. PBR Blaster and some banging of a mallet took the rotor off with little issue. Took about 40 minutes with 1st rotor I struggled with, and second one just came off. I spent about $270 in parts (front rotors, pads and rear pads) I had quotes from $1700-2200.
Having OEM brake rotors lasting into the 200k kms are normal ( '05 4R @ 200k , '00 AcuraRL @ 240k ). In your case the slight pulsations when brakes were applied at hiway speeds strongly indicated/suggested warpage in rotors ( most frequently with front rotors but my '00RL rear rotors caused pulsations when they were warped ). If you'er doing the work yourself, it'll not hurt to check for worn out tie rod ends and wheel bearings while you have the wheels jacked up and off the ground. Also if you have a dial indicator check for run outs of rotors and wheel hubs (w/rotors off ). A previous encounter with a curb can bend hub ( as it did for my '05 4R ). Believe factory specs for rotor run-outs is .000" - .002" max. If you'er confident your OEM rotors are still within thickness specs., have them machine/clean-up for reuse or spares. New non-OEM rotors ( and I've bought a few for my 3 vehicles ) are generally made from inferior material ( China ) and are crab shoots as to their longevity. I've never bought replacement rotors from any dealership so giving them the benefit of the doubt that theirs are of a better quality.
You had quotes of $1700 to $2200 for front rotors and pads? That is insane for a job that takes about an hour.
How do I check these parts to see if they cause the problem?
For tie rod joints, you can just use your hand to see if they are loose, i.e. try to move them back and forth. Or have someone turn the steering wheel from side to side while you look at the joint. If the tie rod moves without moving the wheel, the joint is loose.
Ball joints are a bit trickier to check out & takes two people. First jack up the car until the tire is just off the ground. While your co-worker watches the ball joint closely, use a long breaker bar under the tire to lift it. If the joint is bad, you will see a the top of the ball joint move more than the bottom (control arm) meaning it is loose in the socket.
fkheath's method of checking for worn joints at tie rod ends and ball joints are bang on with a second helper on hand. However if you are a onesie doing these checks, here's what I'd been doing. Jack up wheel, grab wheel @ 12 and 6 o'clock positions and see if there is play when you try rocking the wheel along this axis. If there is play, bad ball joint. Next, grab wheel @ 3 and 9 o'clock positions. If play detected when rocking wheel along this axis, bad tie rod ends. Note#1: when doing the tie rod check, first make sure steering wheel is lock in straight ahead position to immobilize steering shaft. Note#2: if there are plays when performing both these checks ,then you have a worn wheel bearing.
Rotor replacement
So strickly from a braking perspective...Braking on most vehicles tend to show more wear on the front brake pads/rotors. Brake pads will generally last 60k before they need close inspection for wear/replacement. So your front rotors also need to be inspected at same intervals for wear, warpage and other wear indicators (gouges, surface anomalies). Rear brakes also inspected at same intervals, but far less wear will be found due to majority braking is performed by front brakes. So generally speaking, rotors will be safe for '1' round of surface grinding, provided you find a shop that has the machine, knowledge and fair price to perform resurfacing. 1 time only.....that's it! Its simply not worth($$) you time, vehicle safety and personal safety on a DYI part. All this is heavily dependent on your right foot...heavy/light on that pedal. Common sense prevails here. But in your case, with that many miles on your OEM rotors and you haven't turned them at this point......replace them.
I got 240,000 miles on 2004 original Honda Pilot rotors. Then sold at 20 years old. I checked thickness in later years as the erosion became noticable. Always within spec stamped on rotors. I always used factory pads from a dealer. I changed pads at about 80% used up or 20% left. I inspected and cleaned calipers and the rubber piston boots. I always opened bleeder when pushing pistons back into caliper.
The Pilot seemed to solve its little bouts of brake shake on its own, like mentioned here shake can be due to other suspension components. But I was easy on brakes and I did bed-in new pads- not the full heavy bed-in process, but a simpler one because I was not changing pad material or brands.
Pulsating steering wheel while braking that varies by speed is usually uneven pad material deposit on the rotors. If the rotors have enough thickness to be turned, you can surely do that. Many opt for new rotors because finding a shop to turn them correctly, with the time to take them, pick them up, etc. may not be worth the cost/hassle of just getting new rotors. We used to have rotors turned but after 3 shops did them incorrectly, the time to go back, argue, etc. it was better to just install new, OEM rotors. New cheap rotors can be bad from the get go. A little rust on the edges is not a big deal.
Do the rotors!
I started to get pulsation on my original pads and rotors at around 100k. I could clean them up by “rebedding” them on the long mountain descents I often take.
The rotors still spec’d fine in thickness and runout was exceptional but I still decided then that I would replace my rotors when the pads were under 5mm. Also, after 15 years the rotors started to look like crap as far as rust and I had no interest in turning them when I got the new ones for $60/ea.
In the last 10,000 miles the pulsation was becoming more common and i decided to do the brake job “early”. Changing the fronts only but everything went smoothly. Bedding felt great. I will test more on my next trip over the sierras.
Out with the old…
Ps, the grooves look far worse in the pic.
416236d1754965011-brakepad-check-32-000-miles-80-000-miles-101-000-miles-img_3920-jpg
416237d1754965062-brakepad-check-32-000-miles-80-000-miles-101-000-miles-img_3922-jpg
You said rust on inner layer-do you mean inside brake surface of a front rotor?
If yes, your caliper is defective and this could cause the shake!
I got 240,000 miles on original Pilot rotors & calipers over 20 years.
pax at 4
